Oil Checking procedure
Old May 18, 2004 | 09:54 PM
NoSlowCamaro's Avatar
Okay okay..i know you guys will never let me live this one down..but i gotta ask ya..Is there a specific procedure for checking the oil?? I'm assuming that its a deeper sump than most motors, so do you have to run the car first to get an accurate reading?? or can you do it while its cold? Also how long do you wait after a drive to get an accurate reading?? It seems that if i check it cold..i get 1 reading..if i check it right after a drive i get another reading..if i wait 5 or 10 minutes i get a different reading..i dont think i've found a way to get a consistent reading...so what is the trick? Thanks.
Old May 18, 2004 | 10:39 PM
Capn Pete's Avatar
Pull dipstick, wipe.
Re-insert.
Pull dipstick, check level.
Re-insert.
No?
To answer your question though, I think it's best (most accurate) to check the level once the car has been sitting for a few minutes so that all the oil has drained back to the oil pan. If you run the engine, shut it off, and check right away, you'll get a "false" low reading, because there will still be more oil up in the top of the engine that hasn't drained to the pan yet.
Old May 18, 2004 | 10:45 PM
rncotton's Avatar
I always check mine about 10 minutes after driving.
Old May 19, 2004 | 02:59 AM
99blackSS's Avatar
The owners manual recommends waiting something like 5 minutes after the car has run.
Old May 19, 2004 | 01:36 PM
mitchntx's Avatar
Just be consistant.
If you set your oil level with the car stone cold, do that each time. If it's after coming up to temp and sitting for 5 minutes, then do that each time.
Old May 19, 2004 | 02:14 PM
haha..yea i know it sounds like such a dumb question..but i just didnt wanna check it cold..get a low reading, add oil, and be over filling it..Cuz i know on my dirtbike..if you check it cold, it wont register anything..so you could easily overfill by a quart or so, just from not using the right "checking procedure"...but okay thanks for the help. appreciate it..
Old May 19, 2004 | 03:34 PM
Capn Pete's Avatar
Then I think you would want to add more oil?!??? The oil level should always be highest when an engine is cold (I mean, after it's been sitting for a long time) because it's had time for the oil to drain back to the pan (or bottom of the crankcase in your dirtbike?) and you can check the level there. When the engine is running, or just after it's been run, you will see a lower level since the oil is going to be spread throughout the motor. That doesn't make sense that there is no level on your bike until you run it? I think the oil you're seeing there is probably oil that flows past the dipstick, but isn't an accurate measurement of what's really inside?? (unless that's what the book says to do, but it doesn't make sense to me? ).
Old May 19, 2004 | 04:03 PM
Ahh sorry dude..i forget to mention an important part about the dirtbike...Its a drysump. It stores the oil in the frame. When the bike sits for a night or so, the oil drains outta the frame, through the oil line, into the crankcase. The dipstick is located on the frame. So in order to get any reading at all, you have to start the bike, and allow the oil to be pumped from the crankcase back into the frame, than you check the oil..Trust me..it scared the crap outta me when i first got it..I changed the oil, went out the next day..and there was nothing on the dipstick...than found out i had to start it first..So alright man thanks for the help.
Old May 19, 2004 | 05:13 PM
Capn Pete's Avatar
Oh, ok........that makes sense.
Old May 19, 2004 | 07:56 PM
1996 | Z28 SS's Avatar
The oil only takes about 5 min to completely drain back into the oil pan doesn't it? And when I say completely.. I mean as much that will, not ALL of it will because it will be in various passages etc.. Anyway, the highest oil reading should be after the engine has been fully warmed up and then shut down for 5 min. That way the oil has drained back but is still hot. Is that not why there is a "hot" and "cold" mark on the dipstick and the hot mark is above the cold one? (there is a hot and cold mark right?? Or have completely I lost it?)
Thats at least what I always though
Old May 19, 2004 | 09:41 PM
My Red 93Z-28's Avatar
Re: Oil Checking procedure
Is there a specific procedure for checking the oil?? Thanks.
Are you talking about your car or checking YOUR oil?
j/k
Old May 20, 2004 | 01:30 AM
Capn Pete's Avatar
You're thinking of auto tranny dipsticks. Engine oil simply has a range, from "add" to "full".
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
