Ultra-Z hood
Old May 18, 2004 | 06:55 PM
Grave's Avatar
Ultra-Z hood
On the SLP site, it says the Ultra-Z hood is designed to use your stock air box and "generates" up to 15hp on LS1's.
My question is... is this statement true, or just a marketing ploy? The stock LS1 air box isn't designed for ram air applications, is it?
Basically, how does the Ultra-Z work? How does it achieve a ram air effect using a stock air box?
Also, would getting a high-flow lid, or an actual ram air lid to compliment the Ultra-Z hood increase air flow and power gains?
So many questions... I know
Old May 18, 2004 | 07:39 PM
99blackSS's Avatar
15 hp is a marketing ploy. Many people even argue if ram air exists on cars. If there is a ram air effect on cars it cvaries by how fast you are going. I think the ultra Z hood requires the ram air box. Without the intake that seals directly to the hood you will see little to no gains for sure. Personally, I wouldn't buy the ultra Z hood for performance, it's more for appearance.
Old May 18, 2004 | 09:10 PM
Grave's Avatar
Well, I really do like the way it looks, from what I've seen so far.
Maybe in order for it to work properly, you need to remove the lid from the air box? By the way I figure it, if the lid was removed, the air filter would be directly behind/under the scoop, thereby getting the cold air flow.
I'm just guessing there... but it makes sense.
Old May 19, 2004 | 10:35 AM
1badLS1M6's Avatar
I have the Ultra Z hood. If you look at your air lid, you can see a gap under the lid. Thats where the air enters. With this hood, it has the air pointing directly at that gap. There is no seal or anything so I don't know of any true gains, but it does blow air where it enters the lid.
Old May 19, 2004 | 12:04 PM
TraceZ's Avatar
I used to have the ultraZ hood on a 1995 Z. I know it is a slightly different setup than the LS1, but I saw no improvements over my SLP CAI that I had previously.
I think of "ramair" as a gimmic. Unless you are really going ilegally fast, it doesnt really create any PSI in the intake manifold.
That is not to say I would not buy the ultraZ hood. I really like that hood, and it performs as well as any CAI. It looks great, too.
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
