jeff2004 05-17-2004, 06:08 PM My brother has some tires/wheels that he had on his old mustang, but i think they might be too small to fit on my z. The tires say 275/60b/14...i think. so that means that they are on 14" rims, right? I'm not exactly sure what each number on tires mean. I know the first one is the width, but i dunno what it is measured in. And the last number is the rim size, Right? What is the middle number...and what is the letter for??
Jeff
Eric H 05-17-2004, 06:09 PM Correct, they are for a 14" wheel.
-Eric H
jeff2004 05-17-2004, 06:11 PM Ok, so will my car look funny with 14" rims? They seem kind of small. and what are the other numbers and letter for???
Jeff
notstock4long 05-17-2004, 06:11 PM The first number I believe measures from bead to bead, basically the tread part, and it is in millimeters. The second number is the sidewall height, foir instance, truck tires will have a higher number here than the little rubberbands on 22" wheels. The letter is the speed rating, I think Z is the best. The last number is the diameter of the wheel in inches.
Eric H 05-17-2004, 06:12 PM The first number is the width of the tire. The second is the height.
Honestly, I think your car wouldn't look good with a 14" wheel. But I doubt they would bolt on anyway. They probably have a different bolt pattern and backspacing.
-Eric H
jeff2004 05-17-2004, 06:15 PM Ok, thanx for the replies guys. I was jus wondering if they would fit, because if i ever went to the track, these are nice wide tires, and i think they might be DR's too, not exactly sure though. I think you might be right about the backspacing, they seemed really deep. Our cars have a 5 bolt pattern right?
Jeff
notstock4long 05-18-2004, 04:11 PM lol, well yeah, there are 5 bolts, but it is a 5 X4.75" bolt pattern. Get some pics, I have never seen 14's on an fbody
stangitr 05-18-2004, 04:16 PM i think it would look hilarious
ImportedRoomate 05-18-2004, 10:35 PM Originally posted by Eric H
-Eric H
Ill elaborate just a bit. The second number isnt a set measurement, but a percentage of the width of the tire. Therefore, for example, a 275/60 tire is gonna have a (275mm*60%)=165mm sidewall height.
Also, if that size tire you gave was accurate, that makes for a 27" diameter tire which is a little over an inch bigger than standard camaro tires. So your speedometer and odometer will be a little off.
Injuneer 05-19-2004, 12:02 AM I seriously doubt you could fit a 14" wheel on a 4th Gen.... many of us using 15" wheels for slicks have to resort to grinding down the calipers (rear) and adding spacers (front).
notstock4long 05-19-2004, 03:26 PM Originally posted by ImportedRoomate
Is this true Injuneer? That the sidewall is a percentage of the width? No offense IR, but I have never heard anything like that before...
ImportedRoomate 05-19-2004, 10:04 PM Check near the bottom (http://www.tiredefects.com/markings.htm) for aspect ratio :)
I like tirerack's (http://www.tirerack.com/tires/tiretech/general/size_information.jsp) better, its closer to what I said. :)
Injuneer 05-20-2004, 01:13 AM Originally posted by notstock4long
Yes.... that is 100% correct. A "40" aspect ratio tire has a sidewall height that is 40% of the widest part of the tire (section width).
For a 275/40-17
275 = section width, or widest part of the tire = 275mm / 25.4 = 10.83" section width.
Sidewall = 40% of section width = 0.40 X 10.83" = 4.33"
Diameter of the tire = wheel diameter + 2 sidewalls = 17 + (2 X 4.33) = 17 + 8.66 = 25.66" diameter
notstock4long 05-21-2004, 11:56 AM Thanks guys! I have never made the connection before, although I have heard of 'aspect ratio', just never really though about it. So a 315 with a 40 sidewall would be higher than a 245 with a 40 sidewall, right?
Injuneer 05-21-2004, 12:28 PM Yes:
315 / 25.4 = 12.40"
0.40 X 12.40 = 4.96"
245 / 25.4 = 9.65"
0.40 X 9.65 = 3.86"
