jeepz28
05-17-2004, 12:41 PM
how to drop 5 tenths or moer for about $300 so far my mods are moser 12bolt with 4.10's
slp loudmouth
spec stage 4 clutch
and 315/35 drag radials
slp loudmouth
spec stage 4 clutch
1/2 sec for $300jeepz28 05-17-2004, 12:41 PM how to drop 5 tenths or moer for about $300 so far my mods are moser 12bolt with 4.10's slp loudmouth spec stage 4 clutch and 315/35 drag radials simple 05-17-2004, 09:19 PM DIY nitrous or some real drag tires 16" or smaller with wrinkle wall Zigroid 05-17-2004, 11:47 PM get a used CAI off ebay, cut out some weight, perhaps a pcm tune. 5/10ths is alot, $300 is a little. race when its cooler out? :) Stephen 87 IROC 05-18-2004, 08:39 AM Remove 500 pounds from the car. Cost = $0 simple 05-18-2004, 09:14 AM Originally posted by Stephen 87 IROC Remove 500 pounds from the car. Cost = $0 lol or you could do that:D soontobeGN 05-18-2004, 03:11 PM if your fat could diet? meengreen 94z 05-18-2004, 04:58 PM Originally posted by jeepz28 how to drop 5 tenths or moer for about $300 so far my mods are moser 12bolt with 4.10's slp loudmouth spec stage 4 clutch and 315/35 drag radials I know this doesnt have anything to do with your thread, but how is the driveability of the Spec stage 4 clutch? Ive gone through 4 clutches in a little over a year and half and Im looking for something a little more permanent. The car is my daily driver which is why Im asking. Is the clutch basically engaged or disengaged or does it have some slippage? Derrick Redd 05-19-2004, 09:13 PM Originally posted by simple [B]DIY nitrous Ditto. :) hsyr 05-19-2004, 11:50 PM Originally posted by meengreen 94z I know this doesnt have anything to do with your thread, but how is the driveability of the Spec stage 4 clutch? Ive gone through 4 clutches in a little over a year and half and Im looking for something a little more permanent. The car is my daily driver which is why Im asking. Is the clutch basically engaged or disengaged or does it have some slippage? From what I understand the stage IV drives exactly the same as the stage III. Considering that the disc is identical other than one is a sprung hub and the other is solid I would imagine it would be close. I will find out next week since my stage III disc is shot and im putting in a stage IV disc. Don't expect ALOT of miles out of it tho. I think I got 15-20,000 miles on my stage III and its slipping now. But atleast it will still drive when it slips. I think the IV will be very easy in day to day driving. My stage III was anyway. Hope this helps. Jay-Roll 05-21-2004, 01:01 AM Originally posted by Stephen 87 IROC Remove 500 pounds from the car. Cost = $0 I bet that's a lot easier said than done. I can only think of enough stuff to remove that'll equal only about 100lbs. Have no idea where 400 more lbs would come from lol. Getting the CAI or making your own for around $35 bucks or so and trying to get nitrous is probably your best bet. Stickier tires if you can't get the DR's to hook. Some ET streets or maybe drags would cost about that much and allow higher rpm launches and could get you .2-.3 tenths atleast. jeepz28 05-21-2004, 02:32 AM thinks for all your replys the stage 4 clutch is streetable just getting a little use to | ||
