roll cage question
96_LT1
05-17-2004, 09:18 AM
quick question for those that might know. i'm installing my wolfe cage, and it is pretty much done. i'm having trouble with the passenger side door. the arm rest on the door is just a little tighter than it should be and interferes with closing the door unless you force it. the driver side is perfect with no more room tp adjust. has anyone else run into this problem?? the bar is notched and scribed and has fit perfect except for the pass. door. my only thought was to maybe grind a touch off the arm rest or put a notch in it and then paint. any other ideas??
MBonZ28
05-18-2004, 08:06 PM
hmm your hoop could be off, maybe try and get more bend in that door bar
96_LT1
05-19-2004, 12:52 AM
apparently my hoop is a little off. i ordered the rear bars as installing on the sides instead of over the seat, now the driver side is off just enough to keep the hatch from closing because the strut interferes with the bar. everything is where it needs to be. maybe my car is crooked :rolleyes: i guess i'll have to get the over the seat rear bars now. the door seems to close a little better now with a grove in the arm rest. oh well, such is life. it is a kick a$$ roll cage though.
