RPM Issue
ping0317
05-14-2004, 03:02 PM
Need help guys! My rpm is totally off. When I am in idle, it indicate that I am in 3500 rpm and when I start pressing the gas the rpm shoots all the way to red line. What is wrong with my car...
Pneumatic_Tire
05-14-2004, 07:29 PM
does the engine sound like its running the rpm's read on the tach?
ping0317
05-14-2004, 08:04 PM
my car drives really well. It is just my rpm. It is way off...
TheGreatJ
05-14-2004, 11:06 PM
The return spring inside the tach is going bad. You need a tachometer head.
aklim
05-15-2004, 11:07 PM
Sounds like it. ARe the gauges all advailable seperately? Also check the connections around the coil to make sure they are tight and no rust since I believe that is where the signal is coming from for the tach.
ping0317
05-16-2004, 03:43 PM
thanks I will check it out
