350 building
z28ranger
05-14-2004, 02:00 AM
Hey everyone, i'm kindof new at this, i have a 1985 z28 with a 305 in it right now and i want to put a 350 in it, i need to know what parts i need to exactly buy and maybe some pointers how to put it in, or the best way to. if you could email me what i need it would be appreciated. thanx branger2327@comcast.net
z28ranger
05-14-2004, 02:14 AM
well my Z i bought it prolly about 3 or 4 months ago and it has some major choke problems, so its like hell to start up and then when i do get it running, it leaks oil prolly about 2 quarts everytime i go someplace with it, it leaks the oil from every where the engin is just worn out, it has a 305, auto, and carbureted. i don't want to go to fuel injected when i change it, i don't really want to spend a bunch of money on it, if i do spend a bunch on it i'll prolly just buy a crate motor, but if you have any suggestions, please do tell.
97WS6SCharged
05-14-2004, 04:21 AM
Hard to beat a good crate motor. All the parts are matched pretty well and they come with a warranty. You don't get that when you build an engine. :)
z28ranger
05-15-2004, 12:12 AM
i know the crate motor would have the warrenty but, i thought about building a new one from scratch for the learning. i'd like to really know how to do that stuff
97WS6SCharged
05-15-2004, 12:20 AM
Learning is never a bad thing, but it can be expensive. Parts, machine work, and tools aren't cheap. Mainly all the stupid little tools that are necessary to properly assembly a motor is what kills most people's wallets when they build their first motor. I would recommend picking up some books on the subject and see if you still want to tackle the job.
My only major tip for the moment would be to remove the engine/tranny at the same time. Much easier to reassemble everything when it's out of the car. :)
Black6SpdTA
05-15-2004, 12:25 AM
The question everyone leaves out when looking for motor combos-----How much ($) ya got?
Then we'll tell you what to do. Heh.
z28ranger
05-15-2004, 12:28 AM
well i have some money, but like i said i dont' want to spend a lot if i can just buy a crate for 1400ish, i'll check out some books to see what i need. but i just want some kindof idea of what i really need, tools arent' a problem either.
97WS6SCharged
05-15-2004, 12:38 AM
You ever consider doing a 406 instead of a 350? Lots of torque and you can build a screamer for about $2500 bucks. Plus it will bolt your engine bay and no one will know it isn't a 350. They're alot more fun than a 350. :)
Black6SpdTA
05-15-2004, 12:39 AM
The only crate you could find for sub-$1400 would be the generic GM Goodwrench 350 for ~$1200.
If I were you, I'd look for a used 350 Shortblock. They're cheap and have potential. I sold one a month ago for $175. Figure if you can find one for ~$200, that leaves you plenty for a nice set of heads. Maybe a cam, some other bolt ons.
BTW--I'm assuming you want to go carb?
97WS6SCharged
05-15-2004, 12:41 AM
That wouldn't be a bad way to go either, as long as the bottom end of the short block was in good condition. :)
z28ranger
05-15-2004, 01:01 AM
what would a 406 do for me instead of a 350, or whats the difference. i was thinking of going with to goodwrench 350 but if i can get all of the parts cheaper than the crate then i'll do that instead, can you guys give me a list of what i would need exactly besides everything in a standard rebuild kit?
z28ranger
05-15-2004, 01:02 AM
oh and i do want to use a carb instead, or would fuel injected be easier or cheaper?
Black6SpdTA
05-15-2004, 01:06 AM
Carb will be sooo much cheaper/easier.
A 406 gives you more hp, more tq, and more "cool factor" :p The external difference is next to none. Try a search.
97WS6SCharged
05-15-2004, 01:07 AM
Well, the neat thing about a 406 is that you can't really tell it apart from a 350, but it's super simple to get 500 hp out of one vs getting the same out put from a 350. Plus it will make power at lower rpms than a 350 so it will pull like there's no tomorrow. They're just fun motors. I had one in a s10 that made a little over 480 hp at the wheels on a dynojet on pump gas. It wouldn't be cheaper than the crate, but it would definately be more fun. :)
z28ranger
05-15-2004, 01:10 AM
i was doing some research and a 406 is a mopar engine? am i right? are mopars better for performance than a 350? my z i'd like to make a nice performance car out of it but i also will use it for regular everyday use and with gas being around $2.00 or more its will get expensive in the gas factor.
z28ranger
05-15-2004, 01:13 AM
if i did put a 406 in my z would i have to change the tranny and any other components in the car?
97WS6SCharged
05-15-2004, 01:18 AM
No, a 406 is a 400 small block chevy that's been overbored. Your tranny and accessories would bolt up fine, although you might want to beef up the drive train a bit. :)
82355
05-15-2004, 10:31 AM
The external differences are the three frost plugs or if they only have two there is still a boss for one, that just isn't one there. Those are hard to see with the vehicle in the car though. The easy way to tell them apart is by the size and look of the weighted balancer.
