DS safety loop clearance problems
bowtiepwr
05-09-2004, 07:42 AM
>I have a clearance problem ... :(
I have all BMR componets i.e.- boxed subframe connectors , and TrakPak , but the drive shaft safety loop will not fit with the TrakPak .
Has anyone else have this problem and if so what did you do :confused: ?
Xride
05-09-2004, 12:05 PM
will not fit?
how so? I assume that you mean it wont line up with the bolts for the cross brace.
the only reason I can see it not fitting is if it was drilled wrong, or your chasis is bent a bit.
bowtiepwr
05-10-2004, 05:30 AM
>The way the TrakPak torque arm is designed ... it has clearance problems (see link) http://www.bmrfabrication.com/instructions/conv-rear.jpg
even their site tells you this .
Injuneer
05-10-2004, 07:32 AM
I'm confused... BMR tells you on the website:
".....will not fit with BMR Trak Pak."
....and you want to make it fit? Why not ask BMR what DS loop they recommend with the Trak Pak?
PatriotTA
05-10-2004, 11:42 AM
I have an NHRA legal Jegs DS loop that is very close fitting. Check out a pic HERE (http://www.angelfire.com/punk2/fallenworld/images/exhaust/1.jpg) Its only $35 too, so you can't beat that. Just an idea.
bowtiepwr
05-10-2004, 02:11 PM
>way ahead of you ... just have to wait for their response , but I was hoping that someone else had close to the same situation .
you get confused that easily :confused: ;) .
Injuneer
05-10-2004, 03:58 PM
I was just trying to help you get an answer.... since I seem to have offended you in some way, next time I'll mind my own business when you ask a question.
Sorry to inconvenience you. Have a nice day.
bowtiepwr
05-10-2004, 08:03 PM
>Hey man ,
you ddn't offend me I was just being goofy (didn't you notice the " ;) " ?
I applaud your drive to answer all the posts especially ones that are as trivial as mine .
