ianwells100
05-09-2004, 03:30 AM
whats a quick step by step for removing rear springs only, leaving the shocks on?
thanks
ian
thanks
ian
removing rear springs, onlyianwells100 05-09-2004, 03:30 AM whats a quick step by step for removing rear springs only, leaving the shocks on? thanks ian Xride 05-09-2004, 03:48 AM gotta unbolt the shocks to get the spring out as far as I know. but if you can get the chasis high enough, unbolt the lower shock mount, (with a jack under the rear end) and then lower the rear untill the springs come out. that should work, Injuneer 05-10-2004, 01:05 AM I have an online procedure for replacing springs and shocks at the same time. If you are just doing springs, ignore the parts about accessing and loosening the top of the shocks. http://members.aol.com/InjuneerZZ/HALEibch.htm | ||
