JoeliusZ28
05-08-2004, 11:22 PM
My cruise control decided to stop working today... anything I check like a fuse or do I have to buy an entire new unit? (mainly... what fuse do I check?)
Cruise ControlJoeliusZ28 05-08-2004, 11:22 PM My cruise control decided to stop working today... anything I check like a fuse or do I have to buy an entire new unit? (mainly... what fuse do I check?) ishz28 05-09-2004, 12:25 AM See if your third brake light is burnt out, it rides on the same circut as the cruise does. JoeliusZ28 05-09-2004, 12:39 AM Originally posted by ishz28 See if your third brake light is burnt out, it rides on the same circut as the cruise does. thanks I will try that first thing tomorrow JoeliusZ28 05-09-2004, 11:12 AM third brake light still works... thats probably bad news:( ishz28 05-09-2004, 06:30 PM Ok, does your a/c still work? I have a bad compressor, everytime I moved the HVAC fan control past any off the a/c settings to regular fan settings, it would blow the fuse in the engine bay fuse box. I just unplugged the a/c at the unit. Anyway, still check the fuses in the engine bay. JoeliusZ28 05-09-2004, 06:34 PM ill try the ac thing and all the fuses while im at it. JoeliusZ28 05-10-2004, 04:15 PM have not gotten a chance to check that yet... im really busy with schoolwork today:mad: Capn Pete 05-10-2004, 04:19 PM It could just be that the switch is screwed. F-bodies use the exact same switch that older GM trucks used, and a lot of them (switches) die. I know we had that with my dad's old truck, and his friend at work had the exact same problem too......the cruise still worked, but with a new switch;). JoeliusZ28 05-10-2004, 08:04 PM Originally posted by Capn Pete It could just be that the switch is screwed. F-bodies use the exact same switch that older GM trucks used, and a lot of them (switches) die. I know we had that with my dad's old truck, and his friend at work had the exact same problem too......the cruise still worked, but with a new switch;). Is that so? My truck and car have the exact same blinker handles. Niether work now. But it would be nice to pay $5 per vehicle to fix them as opposed to $200 a piece. JoeliusZ28 05-11-2004, 05:39 PM AC is working fine, but I havent checked the fuses yet:o Lower 05-12-2004, 02:41 AM Originally posted by JoeliusZ28 third brake light still works... thats probably bad news:( Did you take it off to check it? There are 2 bulbs there IIRC, which means you might still get light out of it, and still have one burned out, rendering your cruise control unfunctional. Joe Bellman 05-12-2004, 02:39 PM I was in autozone the other day they had a few of the turn signal switch assemblies for sale on a shelf. they are priced much cheaper than the ones from the GM dealer. JoeliusZ28 05-12-2004, 10:54 PM well guys... today the cruise control decided to magically heal itself... hope thats not a warning sign. Thanks for the suggestions though, because the switch might be all my truck needs:) iNF3RNo 05-13-2004, 11:15 AM I have an interesting issue with mine. Takes some cajoling to get it to work. I have do this: -Pressing the throttle in some -Hold the button in (to the right) until it engages and then still hold it in a little more, while I'm still accelerating. If I let off too early, the cruise will come off. Sometimes I will have to keep pushing it in (it not engaging wasn't b/c I didn't hold it in long enough - it just wasn't going to work that time.) -Have to be going 5-8mph under the speed I intend on setting the cc at, because of how I have to hold it in before it will "stick." -Playing with the other buttons on the stick helps too... Basically I avoid hitting the brakes. Capn Pete 05-14-2004, 01:02 PM ^ ^ again, sounds like your switch is dying, since it's getting harder and harder to set (and it's not that it won't work, it's just hard;)). I think the connections inside the switch must be cheap and wear out to the point they don't make good contact anymore?:confused: blind527 05-14-2004, 01:28 PM mine stopped working, but then it was just a wiring problem, it was fixed, i never use it though | ||
