nitrous "wet" or "dry"
Old Sep 19, 2002 | 03:42 PM
americanmusscle's Avatar
Question nitrous "wet" or "dry"
Im not to much of a nitrous guy so i was wondering what is the difference between a wet nitrous kit and a dry shot kit. thanks in advance.
Old Sep 19, 2002 | 04:36 PM
LPEdave's Avatar
In a wet kit, you feed both the nitrous and the fuel in, completely external to the injectors/pcm, etc. In a dry kit, you only feed in nitrous, and "trick" the fuel system to thinking it needs to add a lot of fuel through the injectors.
Dave
Old Sep 19, 2002 | 05:06 PM
kmook's Avatar
Advanced Tech Moderator
Yep Exactly what Dave said.
Also you may want to check out the Nitrous forum, youll learn all you ever wanted to know about nitrous in there and more
Old Sep 19, 2002 | 05:08 PM
95TA8280's Avatar
There's a seperate N2O section of the board in which you could probably get a lot of specific answers.
Old Sep 19, 2002 | 11:42 PM
Brent94Z's Avatar
Super Moderator
Moving to the Nitrous Forum...
Old Sep 20, 2002 | 01:55 PM
Lightbulb
I just want to know one more thing what is it really? I know it is a gas and it runs the $hit out of your engine. Is it really worth it, i mean you blow gaskets and maybe a pistion. just wondering.
Old Sep 20, 2002 | 05:43 PM
KTamez's Avatar
Blowing up engines is not part of using Nitrous. Blowing up engines is part of Improper Nitrous use.
When used correctly theres no reason why you should have problems. This isn't to say continued and extreme frequent use won't have you changing bearings etc sooner then normal, but for the Hobby guy that isn't soraying on a nightly basis, I wouldn't sweat it abit.
Good luck!
Old Sep 20, 2002 | 06:10 PM
Thumbs up
Cool I just wanted to know cause i heard alot of good and bad about it but the bad is what sticks. Thanks for the info.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
