Lou's Short Stick Shifter
Xride
05-07-2004, 04:43 PM
All I have to say is.... is it jsut me or is getting it into reverse a fricken fight???
I have a hurst shifter and jsut put the short stick on, and DAMN am I that weak? or do others fint it hard to get it into reverse with the shorter stick?
MrDude_1
05-07-2004, 04:46 PM
if it takes any extra effort at all to go into reverse, your lockout is not cutting off properly.
you may have to put it in 1st, then shift to reverse, but if you're talking about it being difficult to pass thru the gate past the 5-6 mark, then you need to check your lockout.
the one up top, directly next to the shifter is the reverse lockout connection.
make sure its tight, and then if it still doesnt work, check it for power.
http://josh.swoca.net/board/mrdude/newpics/Connectors.jpg
Mike94ZLT1
05-08-2004, 08:40 PM
Mines a little harder than it was with the regular handle and the B&M. I dont back up all that much so I dont care, its worth it!
