Exhaust Noise
Old May 6, 2004 | 01:48 PM
Rolandolpz's Avatar
Exhaust Noise
I am trying to figure out whether this exhaust noise is normal. Whenever I first start the car and take off, in between shifts (m6) the car makes what I call exhaust farts for lack of terminolgy. A "put put" sound. Maybe its what the board refers to as "Rasp". Anyway, it goes away almost immediately as I continue to drive and the car starts to warm up. It only happens if I take a while to shift between gears.
When I bought the car, the stock muffler was cut out and I believe a flowmaster was welded in its place. There is no marking on the muffler just numbers so I do not know who makes it. Judging from pictures, it looks like a flowmaster.
Anyway, I plan to replace the whole thing but I was just curious as to why it makes this noise and once I replace it with a better exhaust system, that it will go away.
Thank you for your time.
Old May 6, 2004 | 02:25 PM
teke184's Avatar
on start up...the cars run rich...
when you let off the gas, you are hearing a little bit of backfire i would say. it is more noticable with a louder (less restrictive) muffler.
it gets worse if you run a cutout.
i think it is basically unburnt gas igniting in the exhaust pipes.
Old May 7, 2004 | 02:41 AM
mullettour's Avatar
I know on my car when I let off the throttle and coast for a little bit then slowly roll back on the throttle I hear a rumble even after the car is warmed up. I notice it even more with the cutouts open. Usually it only does it when the rpm's are at or above 2k.
Old May 8, 2004 | 09:40 AM
locosteelersfan's Avatar
I've had over a dozen LS1s.
They all do exactly what you described.
Its like a backfire. Don't worry about.
Old May 8, 2004 | 10:38 PM
JoeliusZ28's Avatar
My car backfires like crazy when its cold... it vanishes after about 2 minutes though.
kxrawx
May 25, 2015 08:29 PM
May 15, 2015 10:43 AM
Fatdog2
Feb 12, 2015 12:24 PM
karnykamaro
Feb 2, 2015 01:37 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
