Dyno tuned last night- But did I correct the right tables
Old Sep 19, 2002 | 10:40 AM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Question Dyno tuned last night- But did I correct the right tables
Well went to the dyno last night to tune my friends car. All in all not to bad- before 260RWHP now 280RWHP gained up to 30 hourses in some spots. But did I do the right tables. The car was WAY to rich and had a very up and down fuel curve. The leanest it was before dyno tuning was 10.1:1 AFR and worsse in some spots ( I started with a stock .bin ) I corrected it to around 13.1:1 AFR all accross the board. I made the changes in the %Changesto fuel/Air ratio VS. RPM at WOT. But here is the weird thing- After doing the math to figure out what the AFR for the corrections was suppose to be the #'s were off. The Target #'s that I put in wereabout .3 or point .4 off Now that is not a big deal because I was Dyno Tuning with a AFR meter in the tailpipe, but it makes it hard to tune without a meter. Did I make the changes in the right table- It seemed to work. I am going back to the Dyno next week to countinue tuning, does anyone know what table I should mess with and what tables I should leave alone( Maybe Hal, if you read this post) Also I have a question on shift RPM- I was shifting 1-2 @ 6000 and 2-3 @ 6200 (according to the engine dyno) I know that the Kickdown normal mode shift RPM Threshold and the Normal mode up/down shift points both have to be met to shift, but it is a pain in the a$$ to figure out what MPH to make the car shift at a certian rpm. Can I just set the normal mode up/down shift points lower than they need to be and control the Shift poins from the Kickdown normal mode shift RPM Threshold tables?(Hal) I know that, These are a lot off questions but I am new to tuning and just want to get it right. THanks fot all the Help!! I have a few other questions but I don't want to overwhelm everyone.
HarleyZ28
Oct 5, 2015 06:23 AM
Stay Puft
Middle Atlantic
Apr 19, 2015 11:39 AM
Jlo
Feb 3, 2015 09:41 PM
chevysam
Jan 16, 2015 07:45 PM
SC97TA
Sep 15, 2002 01:10 AM
