TrouserSnake
05-02-2004, 11:05 AM
Today the Car will be started... for the First time in a while...
Just added Hooker Lt's - XE 230/236 - 1.6 rr's - new valve springs - pushrods - plugs and wires.
Today all I gotta do Is put the starter in. Adjust the lash and all the little things like radiator, altrenator and find where all the hoses and wires plug in...
Anything I should look for before I crank the Key?
KGRESOCK
05-02-2004, 11:08 AM
Bleed the cooling system before you fire ,lot of guys
seem to forget that.
Best of luck to you
98cayenne-Z
05-02-2004, 12:04 PM
cool........midland........
were neighbors................
see ya around the big ole tri cities......
MBonZ28
05-02-2004, 03:33 PM
your in for a treat when you hear those duals!
dreamer1q
05-02-2004, 07:45 PM
Best of luck to you How the hell do you do that before you fire it? You mean just fill the waterpump?
TrouserSnake
05-02-2004, 08:20 PM
ok my buddie is comming over to do the final adjustments before we get it going... (plugs and wires)
now.. When I adjust the RR's do you guys do it when its running? or turn the crank and adjust them?
IROC5.7TPI
05-02-2004, 09:45 PM
Turn it over by hand and adjust the lash... otherwise you'll have oil everywhere.
stereomandan
05-02-2004, 11:06 PM
Even if you adjust them with the engine on and the valve covers off, you need to have done it with the engine off first.
Doing it with the valve covers off is like a fine tuning.
Dan
