Do MAF ends work?
Old Apr 29, 2004 | 09:16 PM
zoomjrl's Avatar
Do MAF ends work?
Do the T BYRNE MAF ends really give a 6-8 hp increase or is this like the smooth bellows, where gains are questionable. Anyone have any experience with these?
Old Apr 29, 2004 | 10:49 PM
JimMueller's Avatar
MAF ends make the interior diameter of your MAF slightly larger. This decreases the air velocity, so the PCM thinks there is less load. When there's less load, timing is higher, and that leans out the car a bit. There's your gain.
It use to be 'the thing' to add. Once LS1-Edit came out and many had problems tuning their car accurately because they couldn't measure the new airflow through the ends, it kinda died out.
I had one and gave it away. If you're going to change the MAF, buy one which has a matching PCM flow table, like the 85mm Z06 MAF. You'll still need to have the MAF table adjusted by a tuner.
$0.02
Old Apr 30, 2004 | 03:39 AM
AL SS590 M6's Avatar
Moderator
And then after the puter sees the leaner O2 readings it adds fuel back in and goes back to running like stock except that the load reading that the puter determines from MAF flow are not right.
Old Apr 30, 2004 | 08:47 PM
zoomjrl's Avatar
so basically they cause the same issues that aftermarket MAF sensors/porting do. thanks
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
Krab
Aug 5, 2002 12:08 AM
Geeterman
Aug 4, 2002 04:03 AM
