Shaving my antenna
jeff94z28
04-28-2004, 11:25 AM
Well it goes into the shop on May 11th til the 14th. The 1/4 panel had a dent and some scratchs in it from an accident I was in. I decided to get the antenna shaved while it was all getting fixed
400 bucks damn good deal in my oppinion, very reputable shop too. I would do the 1/4 myself but Im a little worried about my skills on a part as important as the 1/4 panel, plus super chevy is coming up at NED and Im entering my car. Im on a rush to finish my front bumper and fenders so Im leaving the 1/4 panel to the pros.
Check out my link and look at my hood if you wanna see my paint work.
jeff94z28
04-28-2004, 12:48 PM
Im going to throw it under my subs, Im not really worried about reception since I listen to cds about 99 percent of the time.
If it doesnt work under the subs oh well. Ill take it out.
AW/whiteZ-28
04-28-2004, 01:16 PM
If you wanna use your radio you should get something like this
http://www.autoloc.com/detail.lasso?itemid=hab
There are some cheaper ones you just have to look :)
Black_Z28
04-28-2004, 02:23 PM
Originally posted by SVT03
So what are you going to use for an antenna? Are you just going to go without?
You actually listen to the radio??
firebirdjosh
04-28-2004, 02:55 PM
Im trying to shave my antenna right now becuase I am getting the whole bird repainted. I should post step-by-step instructions if it comes out good because this seems like a poular mod.
Drumhawk
04-29-2004, 04:32 AM
One of my pet peeve's about my 02 firehawk is the power antenna pops up even for CD's. Not to mention I never listen to the radio although the new XM radio sounds alright, except there is a monthly fee. :irk:
jeff94z28
04-29-2004, 10:21 AM
Disconnect the power going to the antenna if you never listen to it, that way it will never go up. But try a local autobody place. Probably will be about 300 if your cars black, if not youll need blending and it will be an arm and a leg.
Black_Z28
04-29-2004, 12:06 PM
You'll need blending on a black car too. Black is going to fade much quicker than white or red.
jeff94z28
04-29-2004, 12:10 PM
Black doesnt necessarily need to be blended it is the easiest color to match. I take autobody class at the tech school, black an easy formula to mix up. Where as with other colors, red, yellow, their are big differences.
ibanez6rg
04-29-2004, 02:59 PM
I had mine shaved, looks 10x better. As for the radio, I usually listen to CDs or exhaust tones. ;)
jeff94z28
04-29-2004, 03:38 PM
Exactly, I have a 1000 watt system and I hardly ever turn it past volume 15, I like to hear my exhaust. However on those days with the ttops off 1000 watts does its job nicely.
