New Clutch and Flywheel
Poik
04-28-2004, 01:27 AM
My clutch is slipping, not too bad, but it makes it so I can't make good launches. So I am going to replace the clutch. Does anyone on here have any suggestions for my new clutch, should I just get the OEM replacement or buy an aftermarket one? Since I am having the clutch installed anyways, should I get a lightened flywheel? If so, what are some good brands I can research. Any posts would be appreciated, thank you.
Bud M
04-29-2004, 11:55 PM
SLP sells a steel flywheel that's lighter than stock and a clutch/pressure plate setup that a step above stock. I got mine from TByrne racing.
SLP shows up frequently in group purchases.
nateh
04-30-2004, 10:14 PM
The OEM replacements are not bad. They aren't for high horsepower though. I overpowered mine and switched to a Spec. For stock and somewhat higher, I'd go with a stock replacement. They cost a lot less.
You can spend as much as you want.
