xtremetrans
04-27-2004, 10:13 PM
I have a 95 camaro with 8psi procharger stock engine. Is it ok to use a hotcam?
Is a hot cam ok for a supercharged car?xtremetrans 04-27-2004, 10:13 PM I have a 95 camaro with 8psi procharger stock engine. Is it ok to use a hotcam? engineermike 04-27-2004, 10:30 PM The Hot cam is not good for any car. Time and time again, I've seen cars with much smaller cams run as good or better. Will it run? Yes. Is it optimal? No. Mike xtremetrans 05-03-2004, 08:54 PM What would be a better cam. MEAN LT1 05-03-2004, 09:18 PM Originally posted by xtremetrans What would be a better cam. Something with a tighter lsa. Is this a weekand car or a daily driver. What is your idea of streetablity?. Also whatrpm range will you be shifting at?. All these questions factor in what kind of cam you will be wanting. Is the hotcam a optimal s/c cam?(no). Will i tbe ok for you to run?(yes). But you'll get better results if you have you cam based on what your needs are.:) engineermike 05-03-2004, 10:03 PM For mild build-up's, an Extreme 218/230 - 114, +4. If your heads can handle alot of lift, get an Extreme 214/224 - 114, +4. These lobes are high lift, with .560"/.605" lift. For a more radical build, get an Extreme 224/236 - 114, +4. Mike davepl 05-03-2004, 10:18 PM Let me tell you why I disagree. First, you don't want a tighter lobe displacement angle since that increases valve overlap, which sucks in a boosted application since you wind up boosting the charge right on out the exhaust valve during overlap. Second, you don't need 12 extra degrees of exhaust duration. Those are holdovers from (a) turbo cars that face extra backpressure, and (b) stock LT1 head port characteristics. engineermike 05-03-2004, 10:42 PM Originally posted by davepl Let me tell you why I disagree. . . . you don't need 12 extra degrees of exhaust duration. Those are holdovers from (a) turbo cars that face extra backpressure, and (b) stock LT1 head port characteristics. Thank God. Someone willing to buck the current widely-accepted supercharger cam logic. The 3 cams I quoted are the most popular on the board and have produced good results. I'm about to tear into my motor to remove my "holdover" 224/236 cam and put something in a bit different. davepl, what, exactly do you recommend? Mike davepl 05-03-2004, 11:37 PM Hard to say without knowing a whole lot about your setup, like the exhaust port flow, what type of exhaust, converter, and a whole host of other things. I'm no cam expert, but when I researched mine, I went with a 236/236 on 114 centers for my AFR210 heads. If I had to do it over again, I might try to 218/230 or a 224/224 to regain a little bit of idle quality (its not that bad, but it ain't stock idle quality!). All in all, I'd rather have more boost and less cam :-) Ultra_Dog 05-04-2004, 01:50 PM I have a pretty tame configuration and went with a CompCam 07-305 that has 220-230 114* and .544 lift with my 1.6rrs. The cam has terrific tip-in throttle response and very good mid-range torque. Upper RPM could be more aggressive with a different cam, but with boost, it just comes right up promptly anyway. Since I use 99.99% of my driving on the street, .009% thrasing other cars locally, and .001% at the strip, I didn't see much sense in a pure dragster camshaft. others disagree, but I passed smog, got my tags, and have insurance that allows me to mosey about incognito. There is always someone with a faster car anyway. Going to the local drag strip is always a humbling experience.:cry: carnutz 05-04-2004, 03:48 PM I too have the option to procure a CC305, I tend to think it would work ok in a F.I. engine. The dual pattern witht the added duration on the exhaust side whould seem to augment the blower. Or not? EDS Z28 05-04-2004, 08:17 PM The hot cam isn't all that bad. I made over 500 rwhp with it and a procharger P600B. :) It has a pretty decent idle too. MEAN LT1 05-05-2004, 08:25 AM Originally posted by EDS Z28 The hot cam isn't all that bad. I made over 500 rwhp with it and a procharger P600B. :) It has a pretty decent idle too. Good numbers Ed!, the hot cam isnt going to hurt you at all it just isnt the most optimal cam for a blower application. But from what im reading in this thread it looks like the current accepted blower cam theory has changed or is being changed.:) :confused: engineermike 05-05-2004, 12:31 PM Originally posted by MEAN LT1 . . . it looks like the current accepted blower cam theory has changed or is being changed. I've tried a couple of times to change it, with no luck so far. It seems as though the masses don't want to deviate. There is a car, though, that has run 148 mph in the 1/4 mile with a 355, ported GM LT1 heads, 18 psi boost, and a mild non-conventional cam. My next cam will be similar to his. Mike MEAN LT1 05-05-2004, 01:22 PM Originally posted by engineermike I've tried a couple of times to change it, with no luck so far. It seems as though the masses don't want to deviate. There is a car, though, that has run 148 mph in the 1/4 mile with a 355, ported GM LT1 heads, 18 psi boost, and a mild non-conventional cam. My next cam will be similar to his. Mike I think I may have heard of this person you speak of. has he tried a "traditional blower cam and see what his results were?. Im assuming when you say it not a conventional cam the the lsa isnt 113+. but is it still a split pattern cam? engineermike 05-05-2004, 05:23 PM Originally posted by MEAN LT1 I think I may have heard of this person you speak of. has he tried a "traditional blower cam and see what his results were?. Im assuming when you say it not a conventional cam the the lsa isnt 113+. but is it still a split pattern cam? I really doubt he's tried a "conventional" blower cam, but his results were pretty stupendous for a non-stroker, small-head, smallish blower car. I believe he had a D-1 while most cars in the 150 mph range are YS or F-1. I can't find any back-to-back cam tests in blower cars. You're right, though, in that the LSA is <113, but it is still split pattern, but not 10+ deg difference exhaust to intake. I will be doing the cam swap while the heads are being ported, so I doubt my results will be conclusive, either. Mike Blownbird355 05-06-2004, 01:39 AM Isn't the cc305 and the hotcam pretty close as far as lift and duration??? Whats the HC's LSA. When we degreed my cc305 the lsa ended up being 112 and had a little extra exhaust duration. Would the tighter lsa make me bleed boost?? Ihave the stock s-trim pullies for 7# and I see anywhere from 10 to 12 with the stock heads and 1.5's. carnutz 05-06-2004, 11:50 AM The HC is 218/228 .525 with 1.6's and the CC305 is 220/230 .544 with the same 1.6's. I dont remember what the LSA is on the Hot cam...... Am I getting this, that the general consensis is a blower cam should be more agressive on the exhaust lobe? and have a wide lobe seperation? If so what is the "new idea" that you are trying??? Highlander 05-06-2004, 01:31 PM Hey mike... You recommend a 224-236 in early posts and then steer people away of hte +12 duration???? I did have a 215/220 cam in my S/C an the car did 393@5200rpm. The car was lots of torque fun bla bla bla... but... after 5200 it would die like a FREE FALL!!!!!! I lost 70rwhp from 5200-5600rpm... I went to the 224/236 cam and the rev range went up, but it didn't fall on its arse after its peak.... I had peak at 5750 and had 20rwhp less at 6200+ So i guess the exhaust choked.. maybe it was because my heads didn't flow all that well on the exhaust, but we will find out... I have my new cam 224/236 116LSA high lift version. Now is the time to change it if the results might be proven. engineermike 05-06-2004, 04:04 PM Originally posted by The Highlander Hey mike... You recommend a 224-236 in early posts and then steer people away of hte +12 duration???? I did have a 215/220 cam in my S/C an the car did 393@5200rpm. The car was lots of torque fun bla bla bla... but... after 5200 it would die like a FREE FALL!!!!!! I recommend the 224/236 because it is tried and works reasonably well, but I don't think it's optimal. I haven't tried something different yet, so I'd rather not use someone else as a guinea pig. But. . . if someone is willing to try a little experiment before I get around to it. . . Rather than looking at the intake duration/exhaust duration, LSA, advance, it is better to look at IVO, IVC, EVO, and EVC. Of course these can be calculated using duration, LSA, and adv, but the timing of actual valve events is what tells the real story of what goes on and why. For instance, generic statements about narrow LSA being bad for superchargers aren't necessarily true unless you calculate actual overlap degrees. Mike Highlander 05-06-2004, 04:54 PM Well.. What do you call optimal?? 5-6rwhp more? For instance.. I would like to know what do you consider optimal for a 224 tops intake duration and such. I dont want to go beyond that as I dont want to rev it more than 6300-6400 AT MOST. I think that 224 in a 383 gives you a nice rev range for a street car. I have played a little with EAPro. But it looks like im going to play some more and see what I can come up with, as I prefer to loose $300 right now than having to remove and replace again. After this .. I hope its DONE!!:rolleyes: engineermike 05-06-2004, 06:54 PM Originally posted by The Highlander Well.. What do you call optimal?? 5-6rwhp more? For instance.. I would like to know what do you consider optimal for a 224 tops intake duration and such. I dont want to go beyond that as I dont want to rev it more than 6300-6400 AT MOST. I think that 224 in a 383 gives you a nice rev range for a street car. . . . 5hp, 10 hp, 20 hp, who knows? Nobody's tried it yet. I don't even know for a fact that it will make more power. Your 224 limit on duration is exactly the kind of thing I was referring to earlier. IVC has a large effect on rpm range. IVO has a very small effect on rpm range. So, you can increase duration on the intake without increasing rpm range IF you add it on the IVO side. An example is that a 230 intake lobe on a 108 centerline will make the same low-end as a 224 lobe on a 111 centerline. Maybe 224/230 is optimal, maybe 224/224, maybe even 224/218. Reverse split cams work very well in LS1's, import cars, street bikes (my ZX-10R cams are 245/225), supercharged imports, and turbocharged cars. Hot Rod magazine printed an article on a 200 mph supercharged Civic who's cams were 250/210. Some dirt-trackers are even starting to use reverse split cams, which goes against all traditional SBC logic. Can anyone explain why turbo cars run well with reverse split cams? They have even more backpressure than supercharged cars. And don't say that "they need more exhaust velocity to spin the turbo" because that's a load of BS. Velocity around the valve and velocity through the turbine wheel are unrelated. I built an elaborate spreadsheet that plots piston position, piston velocity, valve position, cylinder pressure, and torque applied to the crank. What I found agrees with David Vizard's SBC camshaft book: supercharged motors retain cylinder pressure later in the power stroke than naturally aspirated. So, you stand to gain more work from this pressure if you delay EVO. This means less duration on the exhaust. Mike Highlander 05-06-2004, 09:12 PM Turbo cars work well with a reverse split cam because of the exhaust back pressure... It closes the valve sooner so there is less chance of contamination of the intake charge and even reversion to the intake. Its not the same thing as my exhaust... I think I am seeing around 5-6psi back pressure at WOT vs 12-15psi boost that I will be seeing.. Gases will flow forward. On most turbo cars its the other way around... You get 10-12psi boost but have 16-20psi backpressure. So that plays a role. On the bike issue... I feel that exhaust headers from bikes are even better designed or combined in length and shape than are the LT1 headers and I also feel that the siamese exhaust port and that not all ports are the same has something to do with the E/I being different than in ls1 cars and bikes. I bet that your bike has a very high E/I ratio or maybe even flows better because of the header tunning, unless you are getting the boost of the ramming effect when going up in speed (100+mph). So all that plays a role in why a bike camshaft is very reverse. I will play with EA Pro and let you know what I find out. engineermike 05-07-2004, 12:46 AM Originally posted by The Highlander Turbo cars work well with a reverse split cam because of the exhaust back pressure... It closes the valve sooner so there is less chance of contamination of the intake charge and even reversion to the intake. Its not the same thing as my exhaust... I think I am seeing around 5-6psi back pressure at WOT vs 12-15psi boost that I will be seeing.. Gases will flow forward. On most turbo cars its the other way around... You get 10-12psi boost but have 16-20psi backpressure. So that plays a role. . . . So, since turbo cars have more backpressure than boost, you must reduce overlap to prevent exhaust from backing up into the intake? Isn't this the same as a supercharged car, where boost is higher than backpressure, so you should limit overlap just the same? You can reduce overlap to prevent both scenarios, boost in the exhaust AND exhaust in the boost. This does not mean that you need a reverse split, though, only less overlap. They use less exhaust duration to take advantage of the pressure remaining in the cylinder later in the power stroke. Let's compare a good NA cam (GM 847) to an accepted turbo cam of, say, 236/230 - 114, +4. The 847 cam is 234/242 - 112, +6. We'll throw the good ole' supercharger 224/236 - 114, +4 in the mix also. EVO: NA 59 BBDC, Turbo 53 BBDC, SC 56 BBDC But I though a boosted motor had more exhaust in the cylinder, so you had to let it out by opening the exhaust early??? Not so. You have more exhaust in the cylinder DOING WORK, so let's keep it there until its done. So, why is the SC cam any different from the turbo cam in this aspect??? That's my point. EVC+IVO (overlap): NA 14, Turbo 5, SC 2 Much less overlap for the turbo and SC cams, as expected. IVC: NA 43 ABDC, Turbo 48 ABDC, SC 42 ABDC This, more than anything else, determines rpm range. I would expect the turbo motor to have a higher rpm peak than NA, all else being equal - which it is not. SC should close intake early to make up for a lack of low rpm boost. So, let's "fix" the supercharger cam by making EVO 3 degrees later (to match the turbo cam). We'll close the exhaust valve (EVC), say, 5 degrees sooner than the turbo cam since a SC motor has an easier time pushing exhaust out due to lower backpressure. We'll keep overlap the same as the Turbo cam, since it is equally important in both, albeit for different reasons. Let's leave IVC alone since we like the rpm range of the 224/236. What does that give us? EVO: 53 BBDC EVC: 3 BTDC IVO: 8 BTDC IVC: 42 ABDC The final spec's are 230/230 - 112.5, +5.5 Any takers? Mike Highlander 05-07-2004, 12:50 AM I will run EAPro now.. give me a sec Highlander 05-07-2004, 01:09 AM I get a final spec of 230/236 on that cam according to ea pro 111lsa 4 advance HP results are RPM --224--230 5500--820--823 5750--853--854 6000--874--875 6250--878--884 6500--866--885 6750--842--860 7000--798--815 AS you can see... up to 6250... difference is negligeable... the difference starts to show when the 224 is too small for the 383 at that rev range and the 230 shines over.. .FWIW 230 is too much... Yes it made more power.. but I still prefer the 224 for ym rev range. The other thing is... you changed the instake duration.... it should have been the other way around ;) Highlander 05-07-2004, 01:20 AM Look what happens when I put 8 EVO in your cam it gives me a 241 exhaust duration RPM --224--230--230/241 cam 5500--820--823--826 5750--853--854--858 6000--874--875--879 6250--878--884--889 6500--866--885--892 6750--842--860--873 7000--798--815--828 See? a higher and flatter curve... and true, the same thing up to 6250, difference is negligeable. but the more intake duration the more exhaust duration you need. Im still sold in the +12 duration in the exhaust.. come on mike convince me!! now is my chance to change my cam. Highlander 05-07-2004, 01:29 AM Now with your cam.. it was 53 -3 here are the results RPM --224--230--241--230/230 5500--820--823--826--816 5750--853--854--858--849 6000--874--875--879--869 6250--878--884--889--872 6500--866--885--892--857 6750--842--860--873--842 7000--798--815--828--796 AS you see... according to EAPro... your selection is worse than the 224/236 cam with more intake duration than the 224/236 cam.. See how both the 224/236 and the 230 230 free fall the same way... the difference is that the 224 freefalls for intake as you can see when you put up the intake in the second cam to 230. but your choice falls because of lack of exhaust... S/C LT1 cars need exhaust is what I believe... Let me know what you think of this... These are my expected FLYWHEEL HP for the YSi-trim. engineermike 05-07-2004, 04:12 PM Too bad we're not racing computer programs. . .;) I have no idea what parameters EAPro uses in its calculations. They may only be considering port gas dynamics, compression ratio, etc. . . without looking at the PV curves / Moment curves to see what happens in the cylinder during the power stroke. I'm not trying to convince anyone else to do this since I don't have hard data saying it works. My recommendation early in this thread was to use the 224/236 cam. I'll try a different cam myself and if it works, GREAT! If not, TOO BAD! Mike Highlander 05-07-2004, 04:44 PM Dont get me wrong... we are just debating here.... EApro uses many things to calc its performance.... Its a nice feauture... The reality is that in 800hp 10 go unnoticed... and you will probably up the boost or do other changes than just a cam swap. Unless its a radical change... I do feel from past experience with my car that the LT1 needs more exhaust specially when supercharging or nitrous.... The LSx doesn't. Im just here debating because my high lift 224/236 cam is waiting to be installed along with the heads and many other things, so now is the time to discuss cam posibilities and options. steve10358 05-07-2004, 08:37 PM If you are going to go through the trouble of swapping cams...why waste your time by going with a Hotcam? Why not get the best cam you can? Seems kinda obvious to me. Highlander 05-08-2004, 11:11 AM Originally posted by steve10358 If you are going to go through the trouble of swapping cams...why waste your time by going with a Hotcam? Why not get the best cam you can? Seems kinda obvious to me. That is exactly what we are trying to determine. RCF925 05-08-2004, 01:57 PM For what it's worth I'm pretty happy with a custom cam I had ground for my 385. I'm still doing some tuning on it and have not pullied up yet and so am at 5psi boost. The grind I used is 228/236 510/525 113lsa +2. This has a nice lopy idle and will make power to 7000 rpm and beyond. I ran my combo on a desktop dyno figuring 8psi and came up with 680fwhp. Right now I'm at about 540 rwhp so the numbers should be close to what I figured before building it. I also looked on the board here at everybody using similar cams for blown applications, but in the end went with what my engine buider recomended when doing the shortblock. Highlander 05-08-2004, 03:35 PM its a very similar cam to the ones we are discussing... maybe too much overlap... I am going with a 116 lsa this time... same duration more lift. 95TALT1 05-25-2004, 09:34 PM with good springs what is the highest lift you can run on a stock lt1 bottom end just wondering cause i am new to the lt1 im an old pontiac man engineermike 05-25-2004, 09:52 PM I'm not sure why the bottom-end would matter. Max lift is more a function of valvespring choice, set-up height, retainer/valve seal clearance, and lifter type. I don't generally recommend over .600" with a hydraulic cam because the open spring pressures get over 400 lb which could compress the lifter at low rpm and shorten their lives. You have to carefully set up the valvetrain to reach .600". With a solid roller, the sky's the limit. How long [or short] do you want your springs to live? It seems like .650" - .670" can be made reasonably reliable. Mike carnutz 05-27-2004, 02:48 AM I think he is asking Piston to valve wise....I think the answer still right around .600 with out pulling the head and claying it.... engineermike 05-27-2004, 07:26 AM Piston-to-valve clearance is dependant on duration, LSA, and advance, NOT max lift. Mike 95TALT1 05-27-2004, 01:27 PM hey mike what might those be engineermike 05-27-2004, 05:56 PM Duration, as in intake and exhaust duration of the cam: more duration means less clearance. LSA as in lobe separation angle: smaller LSA's mean less clearance. Advance as in cam advance: generally higher numbers (positive or negative) will have less clearance. Mike Highlander 08-31-2004, 04:58 PM I might add that Bret did choose the 12º exhaust duration over the intake on my cam? | ||
