guitardedjf
04-27-2004, 12:52 AM
do LED's get hot ? if so, can they melt plastic? are they MOISTURE sensitive?
I'll be doing all of my interior lights in LEDs pretty soon, So i am curious.
AW/whiteZ-28
04-27-2004, 12:55 AM
They get warm but not hot enough to melt plastic. None I've used have anyways :confused:
Red96Lt1
04-27-2004, 01:17 AM
As long as the connections are water proof, so are the actual LED's. And yes, they do not get hot. It only takes a few volts to actally turn them on.
Drumhawk
04-27-2004, 05:57 AM
Originally posted by guitardedjf
do LED's get hot ? :no:
97FormulaWS-6
04-27-2004, 07:50 AM
The LEDs you are most likely to use don't get hot... (5mm, t-1 3/4)
There ARE LEDs that get VERY Hot... I work with LEDs all day, and I have some that will burn you from touching parts of the LED and its required Heatsink.
guitardedjf
04-27-2004, 10:34 AM
I'm going to use the plug and play ones from superbrightleds.com..... the ones with the resistors already built into them....
I think I only need 3 and 5 mm so I guess they should be cool... thanks for your input guys!
