Need help bad!
Old Apr 26, 2004 | 11:14 AM
xjeeper04's Avatar
Need help bad!
hi guys, Im new to this forum but I do have a question for you guys. I have a 1979 camaro with a 305 and a 4 speed, I pulled the engine out and started to rebuild it. well the crank had a bad spun rod bearing so i needed a different crank, I got a different crank and when I went to put the motor back together I relized the old crank is a one piece cranks and the one I have is a 2 piece. so here comes my question, if I used a different block like a newer one that fits my good crankshaft will the manuel flywheel still bolt up and work in my car. To top it off I have to have the car done in 10 days and I need to figure this thing out!
Old Apr 26, 2004 | 04:08 PM
coogsLS1's Avatar
good luck with your problem. Try posting in classic tech too. On a different note, where in nebraska are you located?
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
