LT1 vs. Turbo Talon
djc485
04-26-2004, 12:34 AM
I was on my way home on Friday night and ran into a talon he took the same exit as me and we toyed around for a while until we got to a straight open road. He downshifted and I floored it We went to about 120mph before we shut down I barely edged him out (His nose was at my the back of my front fender). We pulled off to a gas station and bs'ed for a bit. I think he said he was running 17 psi and had a different turbo. I don't if he was telling the truth or not. DSM guys chime in and tell me if that is about right. By the by I have slp headers, random tech catback, orp, and programming.
cndctrdj
04-26-2004, 11:27 AM
i got a friend who is running about the same on his talon and he is putting down about 270 to the wheels so he could have been telling the truth
andol469
04-26-2004, 10:55 PM
Hard to tell based on the mods given, but very possible, especially if only on 17 psi- that hints at still having stock injectors, which means the car probably isn't tuned. Who knows, good kill either way :thumb:
djc485
04-27-2004, 12:35 AM
How much boost can a dsm handle on a stock bottom end?
LT1WanaBe
04-27-2004, 01:01 AM
From what I was told by a guy with 3 eagle talon's (one of which supposedly runs high 11s) the factory pistons can only handle 14lbs??
Cwynn
04-27-2004, 08:40 AM
Boost is set to 10-11lbs from the factory, factory pistons can handle 24-26lbs, the headgasket becomes a problem after 22lbs. With a triple layer metal headgasket and arp head studs, it's not a problem to run 24 pounds as long as you're not leaning out too much and everything else is good.
Boost != horsepower on a turbocharged car. Flow is very important, and when switching turbos, psi becomes irrelevant.
djc485
04-27-2004, 01:54 PM
WHy does the psi become irrelivent? Is it because the turbo spools faster?
Cwynn
04-27-2004, 02:00 PM
Once you swap turbos you flow more air at less of a pressure, so at 10psi on a larger turbo you may be flowing more air than 20psi on the stock 14b, I've had 3 dsms, they're pretty easy to make fast up to 11s, then after that breaking 10s is usually not even worth it.
Cwynn
04-27-2004, 02:02 PM
turbo will spool slower when you go bigger.
hurricaine418
04-27-2004, 07:49 PM
ceramic ball bearing could help spool quicker sometimes even on a larger turbo
Mikey 97Z M6
04-27-2004, 11:43 PM
What year was the Talon? The first gens are quite a bit lighter (90-94) and have better turbo's from the factory. If he upgraded to a 16G turbo with some bolt-ons and 17psi, he would have no problems keeping up. My other car is a 92 Talon. ;)
Mike
djc485
04-28-2004, 10:01 AM
It was a newer pne with the high-rise spoiler. I was just shocked when this happened especially from a roll, usually I walk all over those cars. Another random question. How do you turn up the boost on a stock turbo, is the something tha tblocks or controls the air flow into the turbo?
Cwynn
04-28-2004, 11:04 AM
There's more than one way to do it, the most common is the manual boost controller using a "T" fitting which has a ball and spring to keep air from going through it until there is enough pressure to move the ball back. After the air goes through the "T," it goes to the wastegate which opens and lets exhaust gas bypass the turbine wheel of the turbocharger so it doesn't continue to spool out of control.
