325 50 15 will it fit
Old Apr 25, 2004 | 07:34 PM
ravigogna's Avatar
i am buying rims and tires this week. I am either going with the weld draglite or bogarts 15x10
I wanted to know if any one is running a 325 50 15 on their car and if it fits. Pics would be great
The Section with is 13, diamitor is 28".
Old Apr 25, 2004 | 07:54 PM
Cory1994z28's Avatar
Some people might tell you they will, but do not listen. I am running Goodyear GS-D3's 315 35 R17's on the back and it is a tight fit.... I had to beat the inner finder, cut off the bump stop bracket flang with a torch, and remove the lip on my outer finder (which damaged my body a little). If I had to do it over, I would get 305's. On the other hand my friend is running the same zr1's I have with 315 nitto's and He has ZERO problems.. go figure.. my luck
Old Apr 25, 2004 | 09:04 PM
RacinLT1's Avatar
yes the 325/50/15 is essentially a 28x10.5 tire. there will be clearance issues inside the wheel well depending on what backspace you use,you will have to do some hammer work.
do a search in the drag racing section,there have been a few posts and pictures.
Old Apr 26, 2004 | 12:07 AM
ravigogna's Avatar
Does anyone know what backspace i should use
15x10 with a 6.5" or 7.5"
Or should i go with a 15x9 with a 5.5" back space
thanks for every ones help
F'n1996Z28SS
Aug 23, 2023 11:19 PM
92_RS_305
Apr 19, 2015 01:45 PM
Apr 3, 2015 10:54 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
