What other blowers fit the S-Trim brackets?
davepl
04-24-2004, 02:52 PM
I know a T-Trim will, but its not much better than an S-Trim. Is there a blower that will physically fit in the S-Trim location that will produce significantly more airflow??
bowtiepwr
04-24-2004, 07:18 PM
>If the S-trim and T-trim are the same bracket then the YS-trim (YSi-trim) will also bolt up to to the same bracket per Vortech (with minor modifications) .
davepl
04-24-2004, 07:25 PM
Awesome... but sadly my car is actually a Corvette, which means I need reverse rotation, and they don't seem to make one yet :-(
Highlander
04-24-2004, 09:50 PM
The T-trim is much better than the S-trim... I was planning on putting the T-trim on,but I will put in a YS-trim...
The T-trim in the performance matrix may not look like much more, but in reality its a much bigger impeller, inlet and its HD.
Pro Stock John
04-27-2004, 12:17 PM
S Trim is rated for 650hp.
T Trim is rated for 825hp.
Both make more than that.
