what was the tranny called in the 92 camaro's?
maddog89
04-24-2004, 02:47 PM
were they world class t5's? 92 rs is the car 305
does borg warner make them? any info on a rebuild kit for them? thanks
RedIrocZ-28
04-24-2004, 02:50 PM
You are correct, WC T5 made by Borg Warner if I am not mistaken.
92RS305#2
04-24-2004, 04:40 PM
t5's in the manuals and 700R4's in the autos. thats the extent of my knowledge on em ;)
Marc 85Z28
04-25-2004, 07:48 PM
They were called 4L60s then.
92RS305#2
04-25-2004, 08:09 PM
shows what i know eh :lol:
Stiers
04-25-2004, 08:13 PM
No they weren't. They are called 4L60s starting in '93 with the 4th gen cars.
Here is the RPO code that is in my '92:
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
The RPO code for the 4L60s is diffrent.
camaroguy94
04-26-2004, 01:20 AM
no, 4L60 was correct for 92 and up to 93. In 94 they were called 4L60E
Marc 85Z28
04-26-2004, 11:13 AM
Beginning in 1991 GM changed all of its automatic transmission designations. The TH700-R4 became the 4L60. The newer names were essentially a code for determining the transmission. The 4 meant 4 forward gears. The L meant it was a longitudinally mounted trans, aka rear wheel/4 wheel drive. The last two 2 numbers designated the duty rating, or strength of the trans. The higher the number the stronger the trans.
So GM called the 700 a TH700-R4 until 1990. GM then called them 4L60s. So technically the 91-93 units never were called TH700-R4, even though the are the same transmission.
On a side note, nearly all auto manufacturers have done the same thing. All in the early to mid 90s too.
TheGreatJ
04-26-2004, 07:43 PM
Marc has it straight on this one. The reason for the way the RPO reads is simple: GM didn't want to mess with changing it for just 1-2 production years.....the 4th gen redesign was already in the works.
thork
10-24-2004, 12:17 AM
Hmm, here's my RPO code in my 93 z28
"MD8", which according to fbodmotorsports.com, is the code for "THM 700 R4 auto tranny".
:confused:
I have the 3.23 gear ratio option as well, don't know if that makes a difference or not.
Also, in the 93, it seems like I have the older, yellowish gauges from the 3rd Gen's.
Again, I am new to Camaros, but maybe 93 still had some of the same parts/RPO codes as the older Fbodys?
-Thor K.
Ben91RS
10-24-2004, 04:55 PM
You have a 700R4, but since your car is a 93, it's designated 4L60. Basically, a 4L60 is a 700R4, just with a different name. GM put 700R4s in vehicles from 1984 or so, till 1993. They just changed the name, in 1991, to 4L60. Does that answer your question?
thork
10-24-2004, 06:00 PM
Wasn't really a question, I was just trying to provide more info ehhe. But yes, it helps out a bit, thanks. ;)
Ben91RS
10-24-2004, 10:01 PM
Oh OK, I understand now :thumb:
Tru2Chevy
10-25-2004, 02:15 PM
:confused:
-Thor K.
Yea, in a lot of ways the '93 F-bodies were like a 3rd gen with updated skin.
- Justin
shady54
10-25-2004, 04:43 PM
- Justin
And engine and transmission if you have the 6 speed. witch was the best part :bow:
Marc 85Z28
10-26-2004, 04:38 PM
- Justin
With the exception of a completely different front suspension, the new Gen II smallblock with a completely new intake design, completely redesigned interior and exterior, and some other misc items. Other than that, they're alike :p
Scrote
10-26-2004, 11:49 PM
FINALLY someone else that understands...man. I always get so much crap from people..."no jackass my third gen has a 700r4 not a 4L60...those are the ones that the fourth gens have...." I get that all the time.....
Tru2Chevy
10-27-2004, 02:01 PM
:p
I didn't say in all ways....just in several ways.
- Justin
Z28SORR
10-27-2004, 02:14 PM
:p
- Justin
Well yah! They're both Camaro's, they both are front engine rear wheel drive, they're both built by GM. I quess that's several ways.
Z28SORR
10-27-2004, 02:15 PM
Oh, and just to add to the confussion, they're not BW any more they're TREMEC. That's the 5 and 6 speeds.
Tru2Chevy
10-27-2004, 02:19 PM
Identical rear suspension setup, same driveshaft, same auto tranny, same chip-based computer.....
- Justin
Z28SORR
10-27-2004, 03:04 PM
- Justin
Well there you go! Some more; both have two doors, a hatch back, beat Fords, gas tank in the same location, fuel door's on the left.
How far we going to carry this? :D
