Vortec rocker arm stud
zrs
04-23-2004, 08:15 PM
Ordering some screw in rocker arm stud for the votec heads. I believe they are 3/8 but need to be sure.
Thanks in advance.
Botch
04-24-2004, 03:06 AM
It depends on the rocker arm you plan on running. The part that screws into the head is a 7/16-14 NC thread on both the 3/8 studs and the 7/16 studs. The part that sticks up that you put the rocker arm on will need to match the rocker arms you plan to
use.
Botch
zrs
04-24-2004, 10:11 AM
Thanks for the reply. Now I can order the correct stud and finish off the heads. Again thanks for the info.
RedIrocZ-28
04-24-2004, 02:54 PM
What Botch said, good choice on the vortecs.
