extra vacuum lines
350TPI5SPEED
04-23-2004, 02:28 AM
is there any where to find a vacuum diaghram?? i have 2 extra lines and 2 extra holes, and no they dont go together
WhiteKid
04-23-2004, 01:07 PM
This might help me too ^^^Bump^^^
WhiteKid
04-23-2004, 01:09 PM
Actually I found this already...haha
Vacuum Lines on TPI (http://www.chevythunder.com/fuel%20injection%20vacuum%20lines.htm)
350TPI5SPEED
04-24-2004, 01:03 AM
THANK YOU VERY MUCH THIS WILL HELP ALOT
350TPI5SPEED
04-24-2004, 01:30 AM
OK I looked at the diagram and the line from the throttle body does not go all the way to the egr sol. and the one from the egr valve does not reach the sol. either. the egr sol. is where the stock coil goes right? i have and edelbrock lower manifold and runners obviously stock upper plenum and a bbk 58mm throttle body, you guys have anything??? im stomped and dont want to route the lines wrong. thanks again
WhiteKid
04-24-2004, 01:50 AM
ok i think the throttle body valve and the egr valve both go to the sol. the short one to the egr and the long one to the throttle body
