Looking for various LT1 parts.
tamatt27
04-23-2004, 12:01 AM
I need:
LT1 TB for T56 if it makes a difference,
LT1 serp acc's,
fuel rails,
383 LT1 stroker kit,
wiring harness,
probably some more, but I can't think of it right now.
I also have some B-Body iron heads that originally came with the motor. They only have 15K miles on them, but I bought some aluminum ones, so I don't need these anymore.
E-mail's tamatt27@hotmail.com
96speed
04-23-2004, 08:00 AM
Just an FYI: TB is not tranny specific.
Hope this helps,
Ryan
EddieP
04-23-2004, 12:24 PM
sent mail...
Originally posted by tamatt27
I need:
LT1 serp acc's,
fuel rails,
wiring harness,
'95 LS1 Z28
04-23-2004, 06:09 PM
Not on your list but I have a set of LT4 heads and an LT4 intake with only 500 miles on it all. The intake has the fuel rail and injectors on it too. The heads are stock LT4's but have Crane 10308 dual valve springs on them with crane seats, locks, and retainers too.
All will go for only $1000.
I also have a 60 over 2 bolt main block with cast aluminum pistons, stock rods, stock crank. Everything including the block has only 500 miles on it. $500 or $1500 with the above LT4 heads and intake too.
Let me know if your interested. 940-648-0774 ask for Derek
By the way if your going to do a bored over anything you need to go with an aftermarket TB. The stock one will starve the engine.
lt1ownsall
04-23-2004, 07:15 PM
Originally posted by '95 LS1 Z28
By the way if your going to do a bored over anything you need to go with an aftermarket TB. The stock one will starve the engine. [/B]
folk tail
whitehooptie
04-24-2004, 02:22 AM
48mm = 500 cfm (stock)
52mm = 750 cfm
58mm = 1000cfm
mono = 1500cfm
Not exact numbers but close to it.
96speed
04-24-2004, 11:04 AM
Monoblade is 1300cfm.
The Force EFI big daddy 4bbl style TB is 2000cfm :).
Ryan
