carb to injected??
8_4_berlinetta_
04-22-2004, 09:27 PM
should I get rid of my carb and go fuel injected??
if so what year should I go with??
anything I should stay away from??
how hard is the swap??:confused:
Zepher
04-23-2004, 08:30 AM
swap is easy, go with 90-92 SD.
http://www.transamws6.com/pics/transam/Edelbrock.jpg
http://www.transamws6.com/pics/transam/engine.jpg
or get an LT1,
http://www.transamws6.com/pics/05-2003/lt1_enginebay2.jpg
LiquidSkies
04-23-2004, 09:25 PM
is it stock or aftermarket carb? i love carbs so you know what im gonna say...owned both FI and carb. if your going for cheap easy power = stay carb. going for gas milage and a little bit more dependable = FI. don't get me wrong i like FI, i just find is easier and cheaper to produce power with carbs.
8_4_berlinetta_
04-23-2004, 10:52 PM
I got a edelbrock 600 on there now but still have the stock intake what intake should i swap it too?
LiquidSkies
04-23-2004, 11:27 PM
YES! that stock intake is restrictive compared to a holly or edlebrock intake. you might want to up the carb to a 650 also, depending on the rest of your setup. best thing about carbs is you can do big cams and other mods and not have to worry about ECU programming after ;)
Zepher
04-24-2004, 02:47 AM
I ran a Performer RPM 7101 Dual Plane Hi-rise intake on my setup and it was great. No need to go to a 650, 600 is is fine.
I went with FI because it looks cooler, that is the main reason I did the carb to tpi swap.
steve10358
04-24-2004, 05:45 PM
If it were me, I would skip it. Spend your money on a set of good AFTERMARKET heads. FI is wasted money on some projects. If you don't have it, why get it.
Just my opinion. :)
aklim
04-24-2004, 08:37 PM
Holley has a stealthram kit that will have ECM and everything you need. The stock L98 intake sucks anyways.
LiquidSkies
04-24-2004, 08:59 PM
you swapped to FI because it looked better? dang... i still say get the 650 with a highrise manifold. i dont know why you wouldn't want to up your carb to a 650. its a good base carb that leaves room for future mods. don't up the carb if you have a mild engine though. going to big could cause you to lose power
