joink
04-21-2004, 01:08 AM
I recently rebuilt my engine and it was running OK... i sent it to the shop to have them adjust the valves and they were also going to replace a leaking oil gasket. The shop decided they would have to pull the engine to fix the gasket so i decided to bring it home and do the work myself. When the car was returned it would no longer start so i replaced the starter.
Now it will turn over but not run after it starts.
I am not sure if the distributor is in the right position on my cramshaft. I got these directions from the autozone website.
"To be sure that the number one cylinder is on its compression stroke, observe the rocker arms to see that they are both moving. Then, rotate the crankshaft one revolution until the rocker arms for the companion to cylinder number one are both moving at TDC (top dead center). Align the timing mark and install the distributor with its rotor pointing to the number one spark plug cable in the distributor cap. "
I need to know if that means i position it on the number six piston or if that is wrong...what is my companion cylinder?
