Make an offer
Old Apr 20, 2004 | 12:18 PM
onebad82z's Avatar
Make an offer
Moroso Super Cool Can #MOR-65125:brand new in box never used.Blue finish,NHRA approved.Reduce fuel temperature for a denser air/fuel ratio with this extremely efficient Super Cool Can from Moroso. It features a tough polyethylene outer shell that will never rust and all the internal aluminum parts are designed to last virtually forever. Best of all, it decreases fuel temperatures 20 percent over other cans on the market. The inlet and outlet fittings are 3/8 NPT and the lid is held on with a wing nut and gasket for a leak proof seal. Includes two stainless steel straps, T-bolt clamps, and lightweight aluminum bracket for easy mounting.$100 NEW
Moroso U-Joint Girdles: Made from 7075-T6 aluminum, the Moroso U-Joint girdles have a unique design which provides more bearing surface for the universal joint bearing cap. The result is greater strength compared to conventional girdles. These girdles have an anodized finish and comes complete with fasteners.$20 NEW
*1 part #710-85800:Chevrolet: 1955-82 rear axles with U-bolts; Dana: All Dana 60 axles with U-bolts, aluminum, Gold anodized...brand new never used
*1 part #710-85810:GM: 1965-82 12-bolt, with straps, Red anodized...brand new never used
Moroso #MOR-24350 oil pump pickup for Moroso oil pans.
Fits Chevrolet: 262-400, fits MOR-19510, MOR-19520, MOR-20180, MOR-20181, MOR-20182, MOR-20190, MOR-20191, MOR-20200, MOR-20205, MOR-20230, MOR-21010, MOR-21015, MOR-21900, MOR-21901 oil pans...fits MEL-M55HV, SLP-224-4143 or MOR-22110 oil pumps..installed on oil pump then removed but never installed on motor.$32 NEW
Barry Grant #BGI-140006: -8 AN carburetor inlet kit...Barry Grant/Demon series carbs, braided stainless steel, 9/16 in.-24 thread dual inlet fuel bowl fittings...brand new never used.$80 NEW
MSD #MSD-8401 HEI Dust Cover
This modified HEI dust cover allows you to remove the stock HEI coil in your distributor cap and replace it with an externally mounted coil. By going with an external coil, you increase the reliability and performance of the stock HEI system...used for 1,300 miles.$26 NEW
Prices are what I paid new..make me an offer.Need to sell all.Paypal accepted.Pics on request..have pics of all.
canbaufo
May 17, 2015 10:35 AM
canbaufo
May 5, 2015 03:43 PM
Catmaigne
Dec 25, 2014 12:16 PM
siguy
Nov 27, 2014 10:07 AM
