Hyperspeed97z28
04-19-2004, 09:05 PM
To get a little bit of metal in with the gear oil when doing fluid changes???
this common with 10 bolts ???Hyperspeed97z28 04-19-2004, 09:05 PM To get a little bit of metal in with the gear oil when doing fluid changes??? Hyperspeed97z28 04-20-2004, 06:08 AM TTT.... 25 views and no answers..... :( coogsLS1 04-20-2004, 10:28 AM how much do you have in there? From what I have heard it is fairly common on 10 bolts. Hyperspeed97z28 04-20-2004, 10:14 PM Originally posted by coogsLS1 how much do you have in there? From what I have heard it is fairly common on 10 bolts. it was literally 4-5-6 little pieces maybe the size of bb's not even... Capn Pete 04-20-2004, 10:35 PM Was it like very fine metal shavings (like what you find on the engine oil pan drain plug), or actual "chunks" of metal the size of BB's??:think: Fine metal shavings are normal, and may even appear almost like a solid piece if it's collected together for awhile, but if you got actual metal chunks, you may want to take a closer inspection and make sure there aren't any broken or chipped gear teeth inside. Hyperspeed97z28 04-21-2004, 06:10 AM 4-5 actual bb sized pieces... z28chrizz 04-21-2004, 07:32 AM only superfine shavings in mine... but I do the axle at least yearly, and run semi syn gear oil... bb size... not so good, really gotta find out where that metal came from... rpm4lalo 04-21-2004, 01:47 PM the size of BB's. Not good. maybe a bearing is falling apart? Remove cover and check it out, or have it checked. Rearend hasn't been howling or grinding? Hyperspeed97z28 04-22-2004, 10:08 PM no grinding or howling... havent had the chance to mess with it yet, been working long ass hrs this week :( ishz28 04-22-2004, 11:01 PM I had two big ass pieces of ring teeth fall out:D . Is that bad:think: Maybe that's what the thump-thump noise is when I'm slowing down. Est96Z28 04-23-2004, 03:09 AM Probably from bearing(s), but I wouldn't do anything before they start making noise. Hyperspeed97z28 04-23-2004, 09:47 AM so then I'll be good to put fluid back in and drive it til she blows ?? the rear end that is.. hehe | ||
