rpm4lalo
04-19-2004, 06:01 PM
I have the following combo dynotuned with LT1 Edit:
cc306 with crane 10308-1
1.6 RR and comp R lifters
1 piece pushrods with GM guidplates
jet hot longtubes into dual 3 inch exhaust
electric H2O and ASp crank and alt pulley
stock heads, stock TB and stock intake
Moroso CAi and ported MAF
4.10's and Mcleod single disk clutch.
!AIR, !EGR, !CAGS, !CATS
My 95ta dynoed out 354rwhp and 352 rwtq with 12.7:1 AFR
I ported the heads, having them cut for 2.00, 1.56 valves, 3 angle valve job.
I am adding a 52mm TB and increasing the roller rocker ratio to 1.65.
I am adding 30# injectors.
When I get the car together what changes should I make with LT1 edit so I can drive it until I can get it redyno tuned for thew new combo???
