chevy1963
04-19-2004, 09:02 AM
Ok, I have a TB wet kit, I'm running 12.4 @ 112 and the bottle PSI is around 700-800, I just got my heater to push the psi up to around 1200, should this increase my times since its going to push more N2O into the motor?
JSK333
04-19-2004, 11:00 AM
Yes, big time. There is a HUGE difference between running around 750-800 and 950-1050, in my experience. Feels almost like doubling the shot.
Part of this is that your engine is running leaner once the bottle pressure increases; because the fuel jet/psi stays the same, even though its chosen for 950-1050psi.
When you get to that optimal psi on your bottle, then your AFR is optimal as well, in addition to flowing more nitrous.
So, it's a two-pronged increase, and yes, you'll notice it. :)
chevy1963
04-19-2004, 12:36 PM
what do you think my time will increase to?
JSK333
04-19-2004, 12:44 PM
What brand wet kit? If it's an NX/NW jetting type (RWHP), then you'll probably gain another 5mph. 10 RWHP generally = 1 mph in the 1/4.
