Wilson
04-18-2004, 07:12 PM
If you guys are using the dynotune.xls spreadsheet I posted below the fixed up version. I found several spots in the Column J "Ratio Desired" that was off. This will affect your After PE table (Column C).
Below is the fixed up verison that I verified that is correct. All the numbers match up. :) I've email "LJ" to ask him to update his PCM site where he was hosting the file. In the meantime you can get it from my server.
DynoTune.xls (Fixed) (http://www2.hawaii.edu/~wilsonch/misc/DynoTune.xls)
***NOTE*** 93 fbody's email if you want the modified version of dynotune for the 93. The RPM table values in PE % Change to Fuel/Air Ratio Vs. RPM are different then the 94+ fbodys. :) So, dont use the spreadsheet listed above!
