SMOKNZ 04-16-2004, 09:55 PM I was just curious if you all were using the Eagle ARP rod bolts that come with the rods, or are you upgrading them. I was going to upgrade them to the ARP Proseries bolts, but quickly realized that they weren't going to work when they showed up on my doorstep. The eagle bolts are just bolts, not bolts with a head and a nut like the Pro-series one's. Just wanted to hear if anyone upgraded these bolts.
Bill
97WS6SCharged 04-16-2004, 10:19 PM I ordered mine with the upgrade cause the guy helping me build my engine told me too. Why won't they work for you?
LT1RX7 04-17-2004, 05:06 AM Originally posted by 97WS6SCharged
If I'm reading it right Smoknz bought those T-bolts. The ones that come with Eagle H-beams are just regular bolts, like you would find on headers lets say.
SMOKNZ 04-17-2004, 07:51 AM Originally posted by LT1RX7
Thats correct. I just wanted to know what you all thought of the ARP bolts that come with the rods?
engineermike 04-19-2004, 07:42 PM I've heard really bad things about the ARP 8740 rod bolts that come in the H-beams. Wall-2-Wall racing replaces all of theirs because they've had them break while torquing them down.
I tried to replace mine with ARP L19 rod bolts, but found that they have bigger heads and would mess up the balance and clearancing done with the 8740's. So. . . I got some ARP 2000's that are dimensionally the same as the 8740's, but much stronger.
Call Frank at:
gofaststuff.com
and he'll get the right ones for you.
Mike
arnie 04-19-2004, 08:10 PM Originally posted by engineermike
Call Frank at: gofaststuff.com
Bill, I've purchased engine components from Frank B4. I consider him a good guy to do business with. He's in Illinois.
sleeperz28 04-20-2004, 12:10 AM Bill I ran my 8740ARPS last year, but upgraded to the 2000's. I didnt break any or did I show any signs of fatigue. They are rated at like 800hp. The 2000's are good to about 1200hp(under rated). I would order up some of the ARP 2000. Best place I found to get them is Jegs. The part number is eagle 20,000
SMOKNZ 04-20-2004, 05:58 AM Thanks Guys! I'll get some on order!
Bill
SMOKNZ 04-20-2004, 04:39 PM Jake,
Do you have another partnumber, I tried searching Jegs and also under the ARP bolts and didn't find them. They do have Bolts for ARP rods, but they are just the 8740 ones.
Bill
engineermike 04-20-2004, 05:59 PM . . . or you could call Frank at gofaststuff.com. . . very knowledgable.
Mike
SMOKNZ 04-20-2004, 08:26 PM I could do that to :D I couldn't pull up the website, but I'll search google.
Bill
camarossguy2 04-28-2004, 06:16 PM Im using the ARP that came with them.
Rod bolt i alwasy thought are and RPM thing, S/C motor dont turn high RPMs
Shrug
Highlander 05-16-2004, 07:24 PM Will the ARP 2000 throw out my internal balancing???
is this the ones I need to buy?
Jegs
070-234-6403
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1397&prmenbr=361
Thanks!!!!
engineermike 05-16-2004, 08:07 PM If the ARP 2000's have the same head size as the 8740's, then it doesn't need re-balancing.
My ARP 2000's had the same head size, but according to a local engine builder, the new 2000's have the larger heads of the L19's.
If this is true, it will need re-balancing and probably re-clearancing of the block and oil pan.
Mike
Highlander 05-16-2004, 10:02 PM SStroker Ace told me I needed no rebalancing for the l19
Now I need to find this out as I dont want to throw off the balancing of everything.
engineermike 05-16-2004, 10:47 PM The L19's (and maybe the 2000's) have larger heads than the 8740's. Sooooo, they must weigh more.
Mike
Highlander 05-16-2004, 10:48 PM Anyways I am not exactly sure which ones I have.. so I will have to check it out...
Any way to know?
engineermike 05-16-2004, 11:13 PM It's stamped into the bolt head.
Mike
Highlander 05-16-2004, 11:16 PM I found out... they are 8740s... so... they will be replaced... the reality is that I decided to remove the engine while jacking the car and for some reason it slipped to the PAN and it dented the pan a WHOLE LOT! so... now that the engine has NOTHING but the shortblock on the car.. I guess I have an excuse now to remove it and send the pistons to ceramic coat.. but I guess I will have to REBALANCE the whole rotating assembly.. I will weigh those rod bolts at school to check them out if they are the same weight or not.
racer7088 03-11-2006, 04:18 PM The standard and huge 7/16 ARP 8740 bolts that come with the Eagle H-Beams are dramatic overkill and will not break probably ever unless you do something wrong. These are also run on the large big block chevy rods with great results too. On the small block stuff it's total overkill bt a little insurance too.
I've never had a rod bolt break on me in my life when tightening it!
camarossguy2 03-11-2006, 07:17 PM The standard and huge 7/16 ARP 8740 bolts that come with the Eagle H-Beams are dramatic overkill and will not break probably ever unless you do something wrong. These are also run on the large big block chevy rods with great results too. On the small block stuff it's total overkill bt a little insurance too.
Wow
2 year old post brought back to life!:eek:
racer7088 03-12-2006, 01:20 AM Wow somehow it just got sent to me though! Sorry!
Kevin Blown 95 TA 03-12-2006, 10:05 AM It takes about 3 torqueings with the moly to get rid of the friction and obtain the right torque, or use the stretch gauge which is better in my opinion.
Some torque wrench experiences:
At work, we have a metrology department that has a Snap-On torque wrench tester. I checked my torque wrenches on it, and the Sears Craftsman ones were +-1# across the range which was a pleasant surprise, but the cheaper Made in Taiwan one that I use for wheel lugs was light by a 8-9# at 100# (I re-calibrated it). My Proto was dead on as was my dial recording one which I use on rear ends. The guys at the local speed shop who are machining my engine block gave me their expensive-as-hell Snap-On torque wrenches to check out. One was light by 3# at 50#, pretty close at 100#, and 3# heavy at 150#. The other was 3# heavy at 50#, 6# heavy at 100, and 9# heavy at 150#. These wrenches had been calibrated by Snap-On within the year.
Anyway, this is one reason that I am assemble my own shortblocks and using a stretch gauge on my rod bolts.
