Autocross and Road Racing Technique There is more to life than a straight line
Sportine + roadcourse?
Old Apr 13, 2004 | 08:50 AM
SSTAT's Avatar
I have the ProKit on my camaro and I love it so far. But at mid-ohio it seemed there was a rediculous amount of body roll. I know sway bars and shocks play in but in general how important is it to go to the sportlines, or are there known problems having such little suspension travel at speed? This should probably be in suspension also huh? (sorry)
Pat
OK I'm done-
Old Apr 13, 2004 | 09:18 AM
KeithO's Avatar
If you are only looking at body roll, then (as you say) you can address it with the swaybars or the springs. Swaybars will reduce body roll without affecting the ride quality too much. Springs will affect the body roll but will also influence the ride quality when going in a straight line...
What are your spring rates for the springs that you have? Whay swaybars do you have?
Old Apr 13, 2004 | 09:55 AM
SSTAT's Avatar
All I know is the springs are eibach Prio Kit and the sway bars are the upgraded one(s) that come with the SS package, I dont know specifics. The lower springs do help though, its not just aerodynamics right? The lower the center of gravity the less weight transfer you get to the outer wheels/less lift on the inner wheels of a turn??
Pat
Old Apr 13, 2004 | 05:19 PM
Janny's Avatar
Pat
I'm pretty much certain that there will be only a negligible reduction in body roll with lowering springs if any at all. The real cause of weight transfer is centrifugal force, and since our cars weigh so much to begin with we got a LOT of that. Like others have said, if you want to reduce body roll get stiffer sway bars or stiffer springs.
Old Apr 13, 2004 | 08:31 PM
SSTAT's Avatar
Thanks everyone-
Pat
Old Apr 13, 2004 | 08:32 PM
KeithO's Avatar
Lowering is more to lower the center of gravity of the car. Which (I suppose thinking about the geometry) could reduce some body roll, but not much.
It may be interesting to know your spring rates. The Eibachs should have a colored coating on them and there should be a series of numbers on that coating. This will contain the spring rate. I have to believe that the Sportlines are stiffer than the stock springs (then again, maybe not). The good news is that springs and swaybars are relatively cheap.
Casey_SS
Wheels and Tires
Mar 13, 2007 12:04 AM
Casey_SS
Oct 31, 2006 02:35 PM
IrocSS85
Nov 8, 2005 10:30 PM
LT4Firehawk
Nov 26, 2003 04:47 PM
