newbie needs help please
Old Apr 12, 2004 | 02:15 PM
30696bird's Avatar
Need some help guys. I spun a few bearings in the 96 bird in november so I'm in the process of rebuilding it and figured while I have it apart I would make a few mods. Here there are........ Jet hot headers, cc306,home made ram air,! A.I.R.,!egr,hooker cat-back,pcmforless,taylor wires, ported heads,160 thermo,and all the free mods and a few I'm sure I'm forgetting. Anyways, the main question I have is, for the set-up I have the Machinist doing my heads said if I go with the 1.6 roller rockers I would have more lift but I would LOSE torque, is this true? And also, any advice on the reinstall would be appreciated(I will get engine back from machine shop in a week or two). Thank you.
Old Apr 12, 2004 | 02:58 PM
GreenDemon's Avatar
Torque loss is possible, I guess, higher lift= more power higher up, possible power loss down low. I'd get them anyway.
But I would suggest some head porting and polishing for that 306 of yours- it would probably run a lot better with better flow #s.
Old Apr 12, 2004 | 03:36 PM
Loony's Avatar
Yea, all its doing is moving the Torque range around. You might gain a lil but your torque peak will be like 500 rpms higher err somthin...
Old Apr 12, 2004 | 03:40 PM
30696bird's Avatar
Thanks for the replies........I don't know alot camming. BTW,The heads are being ported.
Old Apr 13, 2004 | 03:46 AM
camaronutt's Avatar
it will indeed mess with torque. like said before, just move it around, but I don't think the added lift is the whole cause of that. When you change the Rocker ratio it also effects the duration of the cam, not by much, but still a few degrees. that will effect the peak torque range, to be about 500 rpm higher, as said before. Good luck sounds like you'll have a good runnin car after all is said and done.
Old Aug 27, 2024 | 07:37 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Re: newbie needs help please
It is still worth doing, go for it
Z28countrymama
Jan 22, 2015 02:50 AM
ssz28
Apr 29, 2003 05:26 PM
greg biz
West North Central
Apr 25, 2003 01:00 PM
lastZ
Jan 12, 2003 05:29 PM
2000zee28
Jan 11, 2003 09:57 PM
