eneal13
04-11-2004, 09:00 PM
does anyone know if the wiring harness from my 3.4l v6 will work if i drop an LS1 in to my car?
if you have done an engine swap, how much did it all cost you?
atl2001
04-11-2004, 09:11 PM
the harness will not work, you are going from an OBD I car to an OBDII motor
oil pan 4
04-12-2004, 05:44 AM
Those 2 engines share no parts.
Other stuff you have to change trans, trans clutch lines, engine mounts, struts springs, trans mounts fuel lines, radiator, exhaust.
There is no way a V6 harnes is going to run a V8.
It will cost a lot a few thousand.
You could check out what I got for my v6 for about $1400, should kill plenty of V8s.
