JVC 12-disc CD changer w/ remote (CH-X1100)
Old Apr 11, 2004 | 04:32 PM
FacelessZ's Avatar
Thumbs up JVC 12-disc CD changer w/ remote (CH-X1100)
This JVC 12-disc CD changer w/ remote (CH-X1100) is practically brand new! I've had it installed in the rear underneath my stock sub box on the drivers side for about 5-6 months and I just took it out...
I bought this brand new from Best Buy for $200 and I still have the remote which works perfectly. Since this was mounted in the rear of the car, it is in perfect condition with no scratches! The magazine is also in great condition! This CD changer works perfectly...
SPECIFICATIONS:
Frequency Response: 5 Hz – 20,000 Hz
Dynamic Range: 93 dB
S/N Ratio: 96 dB
Distortion: 0.006%
Wow & Flutter: Less than measurable limit
Output Terminal: Analog (8 pin x 1); 1.5 V (full scale)/less than 1kÙ
Power Requirement:
Operating Voltage: DC 14.4 V (11 V – 16 V allowable)
Grounding System: Negative ground
Allowable Working Temperature: 14°F to 122°F (-10°C to +50°C)
Dimensions (W x H x D): 9-15/16” x 3-1/2” x 6-7/8” (252 mm x 88 mm x 174 mm)
Mass: 5.1 lbs. (2.3 kg) (excluding accessories)
FEATURES:
World's smallest 12-CD changer
CD-R/CD-RW Compatible
Hung mounting and angled (5 angles from 0° to 90°) mounting capability
CD frequency response 5-20,000 kHz
CD signal-to-noise ratio 96 dB
Shock-proof full-floating mechanism
See-through magazine
High precision 3-beam laser pickup
Track error recovery system
1-bit digital to analog converter
Fast CD access
Magazine lock function
Smart eject
MORE FEATURES AND SPECS:
Thanks to the advanced suspension system, our world's smallest 12-disc changer has proven its superiority in the field. The new-generation CH-X1100 is front finished in Millennium Blue. It's meant for trunk mount, but you might feel like showing it off because it looks so great! The CH-X1100 can play a mix of 12 CDs, CD-Rs, and CD-RWs. While you drive, enjoy the compilation discs you create at home.
Featuring the Quad IED (Injection Elastomer Damper) Shock Absorption System, on the the vibration test bench using random frequencies of random intensities, our changer mechanism survived 2G acceleration to prove its superior anti-vibration and anti-shock performance.
Faster CD Access Time: A Linear Sliding Cam, Linear Sensor, and Four Comb Fixtures for the changer mechanism are combined to greatly reduce access time to tracks and discs.
J-Link Connection: Hooking up a changer to a receiver headunit has never been easier. A single cable allows one-touch connection of audio signals and power between the changer and the receiver. This changer is equipped with a single cable connection. The changer is directly compatible with KD-MX, KS-FX and KD-SX series head units that have changer controls. This changer is not compatible with KS-RT and KD-GS series controllers; unlike previous J-Link changers, this changer cannot be adapted to KS-RT or KD-GS controllers using the KS-U14K adapter.
Mounting Angles: You can install this changer at a 0 degree, 22.5 degree, 45 degree, 67.5 degree, or 90 degree angle. There are angle switching dials on both sides of the unit that must be set to agree with the mounting angle of the unit. The unit can also be hung in the trunk space.
Reset: There is an eject button behind the door that also acts as a reset button if pressed and held down for 3 seconds.
$75 + shipping...
I accept money order/check ONLY! No paypal...
DougE31381@hotmail.com
Thanks!
Old Apr 12, 2004 | 06:48 PM
FacelessZ's Avatar
ttt
Old Apr 17, 2004 | 12:32 PM
FacelessZ's Avatar
Old Apr 17, 2004 | 02:10 PM
93TAWicked1's Avatar
is it FM modulated or does it need a JVC head unit??
Old Apr 18, 2004 | 01:58 AM
FacelessZ's Avatar
its FM modulated
Old Apr 19, 2004 | 01:12 PM
FacelessZ's Avatar
still for sale...
Old Nov 16, 2010 | 02:53 PM
93hardbody's Avatar
Re: JVC 12-disc CD changer w/ remote (CH-X1100)
would you sell me the cartridge?
Aaront810
Aug 29, 2020 09:34 PM
Quickss96
Jan 29, 2016 05:56 PM
WPHIG2
Aug 27, 2015 06:37 AM
GTO2Z28
10
Jun 11, 2002 09:02 PM
GTO2Z28
May 18, 2002 02:44 PM
