how to raise the back end a bit ?
sideways_Into_3rd
04-11-2004, 04:41 PM
I have the prokit in my car right now . and i think that the back end is a little too low (for my liking) and bottoms out a little bit here and there
can i slip a garden hose in my rear springs to raise it up a bit ?
any other methods to raise the back about half an inch ?
Xride
04-11-2004, 04:44 PM
The SS SLP springs have something like that on them, but dont know if its to raise it up or anything though.
If nothing else I saw somewhere had like a shim kinda that raised the rear .5" I think it was.
sideways_Into_3rd
04-11-2004, 04:45 PM
yeah .. a shim would be wicked .. hopefully that person chimes in ... I wonder if its a rubber shim or steel
Xride
04-11-2004, 04:50 PM
you could make a shim couldnt you?
hmm, or you could cut the mount off the axel tube and weld it on higher, but that seems like alot of work.
Janny
04-12-2004, 05:20 PM
I made a shim out of 1/2 inch thick conveyor belt. Good sturdy stuff, but now I need to raise the locating dowel because there is nothing to hold the spring in place. I figured maybe get a muffler shop to weld on wee peice of pipe and I'd be all set.
LPEdave
04-12-2004, 05:57 PM
*chime*
I made shims from UHMW plastic that I put on top of my rear springs. Did it to level the car side-to-side, and also to raise it when I drag raced. Works like a champ.
Take a look toward the bottom of http://www.go-fast.org/z28/suspension.html for some info.
Dave
Shue97_Z28
04-13-2004, 11:16 PM
LPEdave, thats a great idea. I sent you an email asking you a few simple questions. Im usually pretty handy when it comes to ideas like that but I would have never thought of that. thanks man, your knowledge is greatly appreciated.
