master arm switch
blazzinbird
04-11-2004, 12:53 PM
where does everyone have theres mounted?
i am thinking of mounting mine where the traction controll switch was on the center console
97SS0594
04-11-2004, 01:16 PM
camaro's is on the convertable top switch pannel, and the firebird it on the door to the ash tray
blazzinbird
04-11-2004, 01:19 PM
on my 96 t/a it is behind the shifter, i dont want it on the ashtrey
Injuneer
04-12-2004, 11:34 AM
Separate panel, mounted in door pocket, with purge, arm, heater and remote open/close.
http://cjcfo.fbody.com/members/injuneerzz@aol.com/PhotosL/DCP03653a.jpg
MILESF
04-13-2004, 06:29 AM
Mounted mine on the center console behind the shifter.
See my sig..........
JJJ93z
04-13-2004, 10:04 AM
same here.
WS Sick
04-13-2004, 10:35 AM
I like Injuneers mounting, can easily blend in if you use dark ABS plastice for the construction.
Injuneer
04-14-2004, 01:37 PM
Or just spray the aluminum with interior vinyl paint, just like the paint I used on the A-pillar and the radio blanking plate....
http://cjcfo.fbody.com/members/injuneerzz@aol.com/PhotosL/DCP03652a.jpg
12Second3rdgen
04-14-2004, 04:11 PM
I am not a big fan of the hidden switches. I have a 3rd gen Camaro, and it is mounted right beneath the headlight switch. If for some reason a solenoid hangs, my wot switch sticks (really unlikely) or say I were to have a fire, I don't want to have to shut my system off with a hidden switch.
I have my system wired so that 1 covered toggle turns on two relays, one for the nitrous and one for the fuel pump on the nitrous side. If anything happens, I can shut my entire system off, pump, solenoids and all with one swipe at the toggle cover :). Its just my opinion, but if you have a quality nitrous fire like the one at my track earlier last year and your cab fills up with smoke, I wouldnt want to be trying to find my ash tray or secret compartment.
