FormulaLT1Power
04-10-2004, 04:31 AM
I'm really wanting to run nitrous in my 95. Check the sig for mods. I am running 10.5:1 Compression right now. Heard a few people tell me no...and others tell me yes. If yes...what is the max you would run? Thanks.
twister19
04-10-2004, 04:34 AM
I would say max would be 150 shot wet kit.
Spinner
04-10-2004, 04:40 AM
150 is pushing the limits of a stock bottom end. Especially with other power mods... IE: 306 cam.
texasTA
04-10-2004, 05:32 AM
I wouldn't run on that setup more than a 125 shot and I would also be adding to my piggy bank for the BOOM Bitch that is inevitable.
There is also a whole sub-category on these forums for N2O. It has a wealth of info in there. They should be able to give you tons of pointers on nitrous setups.
97WS6SCharged
04-10-2004, 06:30 AM
Well, your bottom end isn't completely stock or so it would seem. I'd say you should be able to run a 150 shot with decent reliability. Just don't turn it higher than 6500 and remember you will need to shift sooner with the nitrous than you would without it. :)
texasTA
04-10-2004, 06:43 AM
Oh, I completely stand corrected. I neglected to notice that you are running forged pistons. 150 shouldn't be a problem
Spinner
04-10-2004, 11:44 AM
Pistons aren't the problem. It's the rods
MEAN_SBC
04-15-2004, 12:08 AM
I wouldn't worry too much about running 150 shot.... There are people around here running more than that on Stock bottom end Lt-1's, and some 200 shot's on Stock LS-1 bottom ends.... I wouldn't worry too much about the rods... It's RPM that really kills rods... If you don't spin it through the roof, I think you'll be fine... Just don't slouch on your fuel system..... I'd even think about a dedicated fuel system... Sounds like overkill, but it's safe as hell... You'd better run a window switch, and think about a fuel pressure safety switch.... My old cast engine went 2 years on stock cast pistons, cast rods, cast crank for over 2 years...... I know that sounds extreme, but I'm Mr. Overkill...:cool:
