Rear tires are rubbing when I hit road dips, what are my options?
lbrowne
04-09-2004, 01:05 PM
I have a long road trip and I don't think my 275s in the rear can take any more rubbing when I hit a dip or bump in the road. (normal driving they don't, but highway + bumps/dips = rubbing)
What are my options aside from putting my old rims back on? Whats involved with bending the inner rear fender lip?
Thanks,
lbrowne
ONELOUDKAR
04-09-2004, 01:11 PM
Very easy fix.... just take the wheels off, look at the fender wall and you will be able to see where the tire was rubbing.... get a hammer and start hammering. My 315/s did the same thing and and took about 5 minutes to fix it with the wheel off.
Have fun
:cool:
-Mike
1msfyter
04-09-2004, 01:28 PM
1.BFH
2.Alighn panhard
3.Cut and trim jounce spacer
4.BFG Big Frickin Grinder
5.Spray on rubber undercoating
Mike383LT1
04-09-2004, 02:04 PM
real easy fix order a set of jounce bumper spacers gm pt#12363935
lbrowne
04-09-2004, 02:35 PM
what is a jounce bumper spacer?
Mike383LT1
04-09-2004, 03:04 PM
its the rubber pad monted on the back frame rail the spacer is aluminum piece about 1/2 to 3/4 thick that fits between th e mount and the pad gm uses them when they put 17x9.5 wheels on i have them with same size tires you have no problems when yo compress the rear suspension the rubber pad will hit the axle tube
lbrowne
04-21-2004, 12:23 PM
hrmm, now that I think about it, the spacer is probably a small plate that would go between the jounce bushnig and the frame...hence a spacer...
duuuuuuuuuuuh. i must need more coffee.
edit: how many should i get, just 2? or maybe 4? how thick are they?
lbrowne
04-21-2004, 12:45 PM
the part number suppleid for these jounce spacers is a discontinued part. They thought they had a replacement part number and that one was discontinued as well. (#10282451)
I think this post should be over the suspension forum maybe, I'll make a cross link to it. I need the car fixed before I go on a huge road trip with the next week!
Thanks guys!
PJS TOY
04-23-2004, 04:36 AM
Here you go
http://www.slponline.com/view_product.asp?PARTNUMBER=80046
Hope this helps,
PJ
