Need reply fast
gav'spurplez
04-09-2004, 12:08 PM
Guys, applied a 3 step process last week
1 scratch x
2 deep crystal polish
3 gold class wax
still have some swirls, if i repeat this process will it help ??
i am going to wash the car now and check back in with your responses
thanks :D
Cmr0z28
04-09-2004, 01:53 PM
Don't waste your time.....go pick up some 3M swirl mark remover part #39009, it will get rid of your swirls. Then just wax over it.
lbls1
04-09-2004, 08:55 PM
Those are too many abrasives and not enough wax, IMO. If you had swirls, the first step should have been a cleaner or a slightly mild buffing polish.
I know a lot of people use cleaner waxes, and they are fine for regular paint maintenance, but you just will not get the best shine from a cleaner wax. If you want the best results, you have to use a pure wax as a finisher. The combo above is just cleaning after each other, and not putting down enough of a cover, shine and lubricating agent, like a pure wax.
So I'd say go and pick up the meguiars pure wax or mothers california gold pure wax, and apply a few coats. Your swirl marks should diminish greatly after that. Do not use synthetic wax (polish) with that combo. If you want to use a syn, then buy the two or three step package recommended by any syn maker and redo your process. Good luck.
Edit: Is that gold class pure wax? If it is, then ok you're in good shape. Come back with a few separate sessions of two coats, and you will definitely see results. Don't use anymore polishes or cleaner waxes though.
