17",18" or both.Z06 wheels question
5H9D0W
04-09-2004, 12:40 AM
What would be the benefit of having two different size wheels.The z06 came w/ 17's in the front and18's in the back.I'm looking to buy some chrome z06 wheels, and I want to buy the right sizes??Where can I buy some center caps for them. btw anyone selling there's. Mike
5H9D0W
04-09-2004, 12:52 AM
What would be the benefit of having two different size wheels.The z06 came w/ 17's in the front and18's in the back.I'm looking to buy some chrome z06 wheels, and I want to buy the right sizes??. btw anyone selling there's. Mike
Zack
04-09-2004, 01:26 AM
search for AFS Z06
get 18x9.5's all around
no real benifit from 17's up front, but you cant rotate them, and thats something you will want with tires in these sizes
carlos64030
04-09-2004, 01:46 AM
It all boils down to the question, what do YOU want to put on your car? Most people put either all 17's on or all 18's...the majority goes with the 18's.
Randomsoleil
04-09-2004, 05:00 AM
I am running the 17 - 18 combo and i like it. with the right tire sizes it gives the car a natural looking rake
SStrokerAce
04-09-2004, 07:24 AM
I have 17" ZO6's on mine.
Aftermarket ones are the cheapest but heaviest. The stock ones are expensive but extremely light and strong, with the later years haveing the lightest and strongest forgings.
Bret
5H9D0W
04-09-2004, 12:48 PM
What do oem z06 wheels weigh. and how much more expensive.I like the afs wheels but really want the best looking and performance buy.I mailed afs to see how much the z06 wheels weigh.I'll post the numbers when I receive them.I just wanted to know if theres any perfomance benefit from 17-18 set-up.If theres not, I will go w/ the 18's. Mike
5H9D0W
04-09-2004, 02:27 PM
One more thing.What tires would be best for track/"street" performance.I'm thinking about BFG g-Force T/A 295/35/18 Drag Radial.Only 224 shipped.What should I use up front.I don't think I will need Dr's up front.Should I keep the same size or reduce the width a bit. Mike
5H9D0W
04-09-2004, 04:41 PM
The 18x9.5 Z06 wheels weigh 23 lbs.That isn't bad at all.Can you guys help me out w/ the above posts.
lastZ
04-09-2004, 05:16 PM
i am also getting 17s all the way around what s the biggest tire i can put on them z06s?
Zack
04-09-2004, 05:48 PM
275/35/18's all around on 18x9.5 z06;s. thats what i have. you can prolly fit the 295 on the rear, but will buldge slightly
275/40/17's for 17x95 z06's
Black01_Z
04-09-2004, 06:31 PM
Those are the best drag radials known to man. Nittos suck by comparison. I had the 17 18 combo before. It looks really good form the 3/4 view both front and rear. Especially with wider tires on the rear. Car looks more natural that way. Now I have 17s all around merely to avoid tire costs on the 18 inch wheels. Mainly because theyre the rears and I constantly have to buy new rears. :o
5H9D0W
04-09-2004, 08:49 PM
Should I get 4 bfg's or two in the rear and anything 275/35/18 on the fronts.I don't mind having 4 dr's by all means,but would a treaded set work better?
lbls1
04-09-2004, 09:10 PM
That is a challenge for 4th gens. The best fit from what I've seen will come from 17's all around, but somehow to me, the 17 front 18 back combo looks the best. You may have rubbing issues from the 18 z06 wheel unless you get an aftermarket with a custom offset for our cars.
In terms of handling, I'd ask around. I know of one person in my club that went with aftermarket z06's 17/18, and although they were great looking, he did report back that handling wasn't as good as with his original wheels and tires. Shop around and do the homework, and I think you will do fine.
Zack
04-09-2004, 10:27 PM
you dont need DR's on the front, get another model BFG, like their gforce t/a or something
1stls1
04-10-2004, 05:56 PM
Not only having 17 all the way around helps for rotating,but also the 17" tire is cheaper than the 18:. Just my .02 PS what is the biggest tire on a 17" up front w/out rubbing?
Greg Nolte
04-12-2004, 10:39 AM
The 18" has a deeper inset. Remember inset... I remember when there had to be a couple of inches difference between the front and rear. :) If you go to the BFG or Nitto web sites they will give you the various dimensions. The only way you can be sure is to get some yard sticks and start measuring. I went with the 18s in the back because the lower shock mount on a 69 goes inside the larger rim but hits on the smaller ones.
