CD Player and Sub Enclosure Questions
Black6SpdTA
04-07-2004, 09:22 PM
#1. The CD player in the TA isn't working. It's a factory 1994 unit. It *sometimes* takes the CD but just spins it. Every time I adjust the volume it "clicks and screechs."
#2. With keeping the hatch area useable (for T-tops :cool: ) where do most of you guys put your sub(s). I'll only ever want something subtle, maybe a 12".
Ramune
04-07-2004, 10:11 PM
Well, I had the same question earlier, here's you answer. It doesn't look like you'll get a 12 incher, but you can get a 10 incher with this (http://www.subthump.com/acamarostealth.htm) and still keep your well for the t-tops.
97FormulaWS-6
04-07-2004, 10:20 PM
You can fit a single 12" in the spare tire well....
Ramune
04-07-2004, 11:49 PM
Eh, is it worth the loss of the spare to you?
browneye97ss
04-08-2004, 03:30 AM
Maybe you guys are not looking hard enough in the Subthump site that RAMUNE posted. There are multiple boxes for 10s and 12s that will still allow you to use your T-tops and place subs in mulitple locations in the back hatch area. Some to consider are the Millhouse box ( I have and love this one) which will hold 1 or 2 - 10s or 1 - 12. There is also the T-top box that takes up the entire T-top well, but has a built in slot to store your 2 - T-tops in the box. This box will hold 1, 2, or 3 - 10s or it can hold 1 or 2 - 12s. Or you could get the Passenger Stealth box that will hole 1 - 10 in the Passenger side. Or you could get the Driver Stealth box that will hold 1 -10 or 1 - 12 in the drivers side. Or you could do a combo of a couple different boxes if you like. Hope this helps. You can find all of these boxes on the Subthump website by using the link that RAMUNE put up. Just need to look around a little harder.
