jp2002ls1
04-06-2004, 07:07 PM
Which would flow more air into a carburated C4 corvette engine compartment?
1. Cowl induction with a hood scoop with the back open on it.
or
2. Ram air, with the front of a hood scoop cut out to flow air in like ram air?
I need to know tonight so any suggestions will be appreciated. Thanks.
Hot Rod Hawk
04-06-2004, 07:59 PM
#2 is a airgrab'n force feed when ever in forward travel.
#1 relies on high pressure building up and rolling itself into the cowl. MPH is needed for this action to happen. #1 being open at the rear of a hood is also known to create underhood pressures that can cause your temp to run higher on the motor due to the fan having to deal with a force working againt it.
I'd go #2
jp2002ls1
04-06-2004, 08:57 PM
Thanks Hot Rod Hawk. I am leaning toward the ram air with the front of the scoop inlet for air.
Anyone else have any suggestions?
IrocSS85
04-07-2004, 12:30 AM
forward facing scoop for function, rearward facing scoop for better looks on your car IMO. did that guy give you a refund or what john?
jp2002ls1
04-07-2004, 07:35 AM
C5west agreed to take back their crappy product. I'm going to install the Greenwood hood scoop which is perfect compared to the previous companies.
