KillerTA
04-06-2004, 01:31 AM
I don't realy know much about ohms or what they do, but which way is better?
I have a RF 800a2 amp if that helps.
Thanks!
Thanks!
Should I wire my jl 12w6's to make them 6 ohm or 1.5 ohmKillerTA 04-06-2004, 01:31 AM I don't realy know much about ohms or what they do, but which way is better? I have a RF 800a2 amp if that helps. Thanks! firebirdude 04-06-2004, 12:39 PM 6 ohm, then bridge the amp. Know how to do that? KillerTA 04-06-2004, 01:38 PM Originally posted by firebirdude 6 ohm, then bridge the amp. Know how to do that? I have NO idea how to bridge the amp. firebirdude 04-06-2004, 02:58 PM You will need to use a series/parallel config for the subs. Follow this (http://www.jlaudio.com/tutorials/index.html) link, then click on the "Wiring your DVC subs" or something like that. On the next page, click on Two DVC subs series/parallel. That will scroll you down to the diagram. To bridge on amp, you just use the positive from one channel and the negative from the other. | ||
