95Zman
04-05-2004, 10:52 PM
If so how do you wire it up to the coil? I figured out that the green wire isnt used and that the black wire goes into the tach/pulse terminal, and the yellow goes into the bat terminal with the red pluging into the old bat terminal harness. Am i close? Thanks for any help:confused:
94Zpower
04-06-2004, 08:47 AM
if my car wasn't still in storage I could take a look and tell you , if no else replies I could get you the info next week.
or try pm'ing MTXEXPERT he might know.
95Zman
04-06-2004, 04:39 PM
Thanks for the reply but i went ahead and talked myself into buying the harness today. thanks again
dkeers
04-06-2004, 05:56 PM
Good idea. Using the harness makes it so easy to install, and if the ignition ever fails, all you have to do is unplug the harness and plug it back in like stock.
